Cat5e For Phone Line - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Like Tree1Likes
  • 1 Post By Bob Sanders
Old 11-28-2018, 10:24 PM   #1
Rewards Points: 219
Cat5e for Phone Line
I move into our modular home back in 2013 and they use {looks like} a cat3 or cat5 cable and only use the Blue an white wire in the middle of the RJ11 . I had run in my rooms cat6a wires thru the walls to the basement in a couple of rooms. I would like to use up some cat5e cables I replace for my phone jacks. My question is can I use the same 2 wires {Blue/White}on the cat5e or do I need to use 4 wire {Blue/White/Orange/White}.
Only 1 room uses a printer/fax the others are for phone base.
bote110 is offline   Reply With Quote
Old 11-28-2018, 10:46 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 208
Re: Cat5e for Phone Line
You only need a single pair for phone service. But if you are only using for phone/fax why replace the existing cable?
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 11-28-2018, 11:04 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,184
Cat5e will work fine for phone lines. You only need two wires (one pair) for the line. If you have more than one phone line just use another pair within the same cable.
Old 11-29-2018, 10:36 AM   #4
Rewards Points: 219
I have 3 50feet each of cat5e and the phone line is 100ft of that old thin line you buy at a dollar store for the phone. If I use the cat5e cable do I use a cat5e keystone jack and wire by color code ? does the RJ11 fit in it? I need to add a couple of phone lines 1 for the fax and another for the phone base. So I do the same as the home builders and use the Blue an white wire in the middle of the RJ11 an crimp?
Old 11-29-2018, 12:03 PM   #5
Rewards Points: 1,304
wire things to specs and they'll work fine. you may damage the outer pairs in an RJ45 if you insert an RJ11 into it, but it'll work fine for voice.
u3b3rg33k is offline   Reply With Quote
Old 11-29-2018, 12:49 PM   #6
Super Moderator
joed's Avatar
If you use the cat5e cable, split out one pair and use a standard rj11 phone jack. Leave the unused wires disconnected. I usually back wrap them around the cable to keep them neat.
Old 11-29-2018, 04:16 PM   #7
Rewards Points: 219
was just looking at the phone jack that was install by our modular builder and they use a cat5 keystone jack in the kitchen. But I think I'm going to go with a regular keystone phone jack {cat3} and use my cat5e wire. Now if my fax is being use by the same phone number and my phone base is connected to another phone jack do I have to use the 2 pair connection Orange/Orange White/Blue/Blue White ? My line goes to my modem supply by Comcast .
Old 11-29-2018, 06:00 PM   #8
Super Moderator
joed's Avatar
Unless you have multiple phone numbers all the jack get connect to the same pair.
Keystone jack come in rj11(phone) and RJ45(network) version. Just use the rj11 version or phone jack will be loose and poorly connected.
Old 11-30-2018, 11:29 AM   #9
Rewards Points: 219
Now if I wanted to add more phone jack to my 3 bedrooms do I use a patch panel like they sell at Home Depot or Lowes . Connect all leads to the panel and 1 line to the modem will that work? https://www.homedepot.com/p/Commerci...5570/206415633
Old 12-01-2018, 11:17 AM   #10
Bob Sanders's Avatar
Rewards Points: 2,536
Yes.
chadhyett likes this.
Covfefe!
Bob Sanders is offline   Reply With Quote
Old 12-06-2018, 02:02 PM   #11
Rewards Points: 1,534
is there some user still paying a second line for faxes??
carmusic is offline   Reply With Quote
Old 12-08-2018, 11:20 PM   #12
Rewards Points: 219
I just got some RJ11 and Cat3 Keystone Jacks , Now I planning on using 1 of my Cat5e cables and going to connect my Blue/Blue White in the center of my RJ11 and and 3pin an 4pin on my keystone jack. I was thinking of adding a 2 keystone wall plate and another RJ11 on the same cat5e cable using one of the unused pairs and connect them the same way as the blue wires using the 3pin and 4 pin and connecting to the center of the RJ11 . Should work right?
Old 12-13-2018, 12:16 PM   #13
Commercial sites... yes.
There is also DSL (telephone, tv, and internet over phone line) which is what I have (only I have discontinued land phone line service in favor of cell phones). It's still 2 wires though, but it's all cat 5 which is used because it's twisted to reduce cross talk.
Covfefe!
Main Line Clog Master Brian Plumbing 46 09-06-2012 09:38 PM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 10:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
