Yamaha Scooter - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-06-2015, 07:28 AM   #1
Rewards Points: 14
Yamaha scooter
I am working on a yamaha scooter. Should there be fuel pumping out of the fuel pump when I turn the motor over? And if so what would make it not pump out?
Racer01 is offline   Reply With Quote
Old 08-06-2015, 07:59 AM   #2
Retired Moderator
Rewards Points: 7,174
I'm not much of a scooter expert==but most motor cycles do not have fuel pumps--gravity feed---
Does this one have a pump?
Old 08-06-2015, 11:35 AM   #3
Rewards Points: 202
Likewise, my first thought was "what fuel pump", but makes sense as scooters are configured differently than motorcycles, so gravity might not work. Besides that, you said fuel pump, so it must have one! So, to your question, where is the fuel coming out of the pump? The line going to the engine? If you're cranking the engine with the line disconnected, and don't want it to pump, you probably just need to pull a fuse if it's electric, or disconnect the suction line from the crankcase if it's a pulse type. If the fuel is coming out a screen in the pump, I would guess that the diaphragm is bad.
Old 08-06-2015, 06:12 PM   #4
Rewards Points: 14
It is a brand new fuel pump and I have two that are doing the same thing.
Old 08-07-2015, 09:48 AM   #5
47_47's Avatar
Rewards Points: 320
Did you check the neoprene (rubber) lines? The inside may be deteriorating from ethanol in the fuel.
Also did you check the filter?
47_47 is offline   Reply With Quote
Old 08-07-2015, 07:50 PM   #6
Rewards Points: 14
Cant be a filter because it flows good to the pump but just wont come through. I have two the are doing the same thing.
