White Smoke Then Dies - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree6Likes
  • 1 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By de-nagorg
  • 1 Post By vinced1213
  • 2 Post By vinced1213
Old 10-04-2017, 10:45 AM   #1
Rewards Points: 8
White smoke then dies
I have an Ariens riding lawn mower with a briggs model no. 331777-2372-g5 engine. I was mowing lawn the other day and all of a sudden the mower started bogging down and then let out a giant puff of white smoke from the muffler. I have never had this issue before. The mower starts up fine and runs for about 30 seconds and the same thing happens again. I dont know where to start or what this could be. I am new to the area of small engine repair. Thanks.
vinced1213 is offline   Reply With Quote
Old 10-04-2017, 12:05 PM   #2
retired framer
Rewards Points: 20,006
Re: White smoke then dies
Check the gas for water.
Windows on Wash likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Sterling_1 (06-05-2018)
Old 10-04-2017, 09:15 PM   #3
Rewards Points: 1,466
Screw the dip stick back down.
Old 10-04-2017, 10:01 PM   #4
JUSTA MEMBER
Rewards Points: 3,950
Add some "heat" water replacer in the fuel tank.
Sounds like a possible bad fuel.
Was it sitting out in a rain storm?
Or did your fuel can develop a condensation of water, over a few days of heat and cooling nights.
Always use as fresh as you can get of gasoline in any small engine, they are very picky about their fuel.
ED
de-nagorg is offline   Reply With Quote
Old 10-04-2017, 11:56 PM   #5
Rewards Points: 1,251
I had the exact same thing happen to my Murray riding mower with a Briggs and Stratton motor. Check your oil to see if it is full of gasoline.
What happened with mine was the carb float needle was allowing fuel to flow into the cylinder even when turned off. The fuel seeps down into the oil well and eventually fills it up with gasoline.
You'll need to either install a manual fuel shutoff valve or replace the needle.
KHouse75 is offline   Reply With Quote
Old 10-05-2017, 12:43 PM   #6
Rewards Points: 8
The mower was stored in a shed so it was dry. The gas was the last of the gas that was in the gas can so that could be the issue. It was premium gas with no ethanol so I done know if that makes a difference. I bought a new carburetor and am planning on changing that, draining the gas, changing the oil and spark plug and putting in an inline gas shut off valve. I wont be able to do the work until the weekend. Hopefully this solves the issue and its not more serious. The mower is only about 3 years old.
Old 10-05-2017, 12:48 PM   #7
retired framer
When you get smoke the colour is a clue.
gas = black smoke
oil = blue smoke
water = white.
Bret86844 likes this.
Old 10-05-2017, 12:48 PM   #8
JUSTA MEMBER
A near empty gas can stored over a little time WILL condense water out of the air.
You probably accidently poured this condensate into your tank, then ?
just clean out the fuel system, and try with FRESH gas.
ED
Nealtw likes this.
Old 10-05-2017, 01:10 PM   #9
Rewards Points: 8
Thanks for the info. I will let you know how it goes.
Nealtw likes this.
Old 10-09-2017, 07:28 AM   #10
Rewards Points: 8
Well... after all the work is complete it looks like a success. Everything seems to be working good so far. I hope it stays this way. Thanks for your help!
de-nagorg and Nealtw like this.
The Following User Says Thank You to vinced1213 For This Useful Post:
47_47 (10-09-2017)
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Smoke detectors and reaction time Red Squirrel Safety 4 02-23-2012 08:15 PM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 01:01 AM
glazing white builder grade cabinets - how to get this look? denemante Painting 1 11-04-2011 07:13 AM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 12:24 PM
