What Is This Noise ? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-30-2015, 08:06 AM   #1
Rewards Points: 996
what is this noise ?
i have a 2y/o toro recycler (my neighbors new remington also does the same exact thing).
when cutting heavy and/or thick grass. the machine will develope a clattering noise. bout sounds like it threw a bearing. i then tilt the machine up in the front, and grass lumps start flying out in a rhythmic fashion . after a 1/2 minute the grass stops flying and the noise goes away. i know the grass is causing the noise, but what is the grass doing in there ?
Fix'n it is offline   Reply With Quote
Old 05-30-2015, 08:58 AM   #2
Rewards Points: 2,378
Make sure the nut holding your blade is on tight; could be loose.
How high off of ground is tip of blade (cutting height)? Might be cutting too low for height of grass.
bob22 is offline   Reply With Quote
Old 05-30-2015, 09:12 AM   #3
Rewards Points: 996
i sharpened the blade not long ago, it was not loose.
tipping = i just push down on the handle and the front of the mower goes up some. or, i can just go onto a hard surface(driveway etc) and the mower will clear up.
i mow high'ish. but it has been raining often, and my weed&feed, the grass is growing fast.
Old 05-30-2015, 09:23 AM   #4
General rule is not to remove more than 1/3 of the grass length per mow.
First site I came to:
http://www.diynetwork.com/how-to/out...-cut-the-grass
You may need to mow 2x's week till things slows down. Sounds like the cut grass is too much for the mower to handle.
Old 05-30-2015, 09:27 AM   #5
Rewards Points: 996
yeah, i know that. but because of all the rain, it gets done when possible.
my question is = what is the grass doing to make the mower noisy ?
Old 05-30-2015, 09:39 AM   #6
Rewards Points: 1,510
Doing bout the same thing a playing card does when attached to a bicycle so the spokes hit the card.
Old 05-30-2015, 05:27 PM   #7
Rewards Points: 996
i thought that to. but the noise is not steady . if i can i will try to get a video of it. but don't hold your breath = it is supposed to rain all day here.
Old 05-31-2015, 12:47 PM   #8
John
JD367's Avatar
Rewards Points: 206
This will occur in wet grass,because it clumps up,and sticks to the deck.
Do you clean the underside of the deck,after each mowing ?
If not, it could be ready to clean the dried on grass.
JD367 is offline   Reply With Quote
Old 05-31-2015, 07:46 PM   #9
Rewards Points: 996
yeah, i just scraped off a big pile today. i need to try the water hose connection on it.
Old 05-31-2015, 08:18 PM   #10
Once dried the water hose will do nothing. Once cleaned, hose it after each mowing while it's still wet.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Fix'n it (05-31-2015), JD367 (05-31-2015)
Old 06-02-2015, 11:07 PM   #11
A Little Of Everything
Rewards Points: 1,418
This is your most likely culprit. You've got grass banging around in there that can't get out, and it's too heavy to chop up finely and drop down.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
JD367 (06-03-2015)
Rattling Noise from Roof when windy drgillian Roofing/Siding 6 10-17-2018 07:35 AM
Condenser fan noise and then blade breaks. whotheguy HVAC 11 09-30-2013 07:59 PM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 09:16 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
