Uneven Mowing - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
Old 06-30-2020, 06:57 AM   #1
Rewards Points: 404
Uneven mowing
Wondering what might be causing my mower to leave a small strip of unmowed grass towards the middle of the mower deck maybe slightly off center ?
shirbon is offline   Reply With Quote
Old 06-30-2020, 07:08 AM   #2
ZTMAN's Avatar
Rewards Points: 638
Re: Uneven mowing
What mower do you have?
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 06-30-2020, 07:43 AM   #3
Rewards Points: 19,092
Re: Uneven mowing
As blades wear they get shorter.
If you have a 2 or 3 bladed rider the deck is built so the blade cuts over lap, if the blades to short it will leave a gap.
Old 06-30-2020, 08:29 AM   #4
Rewards Points: 404
Re: Uneven mowing
Yeah i thought of the blades being wore and shorter but it does the same thing with the newer bagger blades as with the older regular blades. The newer bagger blades have only been used a few times they cant be wore and shorter yet i would think.
Old 06-30-2020, 09:09 AM   #5
Rewards Points: 7,042
Re: Uneven mowing
A few things that can cause mowing problems:
grass too tall
travel speed too fast
blade (s) installed incorrectly
no blade overlap ( wrong blades )
deck underside caked with old grass cuttings
engine r.p.m. and or blade tip speed less than designed r.p.m.
mulch plugs
deck design
Edit: Edit:
lenaitch and ZTMAN like this.
Old 06-30-2020, 10:32 AM   #6
Rewards Points: 404
Re: Uneven mowing
Senior Sitizen, , I dont think any of the above are the problem though. Maybe its the blades but sure doesnt seem like it should/would be
Old 06-30-2020, 10:38 AM   #7
Rewards Points: 104
I would also make sure that the front of the deck is about 1/8 to 1/4" lower than the front (if it's adjustable, and it usually is).
Also make sure the blades are properly sharpened. They shouldn't be razor sharp, they should be just about butter knife sharp. They'll dull too quick if they're too sharp, make sure the correct angle is being kept on the cutting surface. Often times new blades will also need a quick hit with a file to get a good edge on them, my brand new cub cabet had pretty rough looking blades right from the factory.
Joeywhat is online now   Reply With Quote
Old 06-30-2020, 10:39 AM   #8
Rewards Points: 104
Also check the deck belts, make sure nothing is slipping and the belt and pulleys are good. Pulleys should spin freely without the belt, and belts shouldn't easily slip on the pulleys.
Old 06-30-2020, 02:05 PM   #9
Mike Milam's Avatar
Rewards Points: 440
Re: Uneven mowing
Forgive my ignorance, but how would a blade get shorter?
I discovered long ago if I mow when the grass is too damp, the mower wheels press the grass down and the mover can't vacuum it up fast enough to cut it so when I was done cutting I had strips of grass taller than the rest.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is online now   Reply With Quote
Old 08-01-2020, 09:14 AM   #10
Rewards Points: 404
Re: Uneven mowing
yeah, still dont make sense to me. No way to adjust / level the deck, no adjustments anywhere. I give up.
Old 08-01-2020, 09:34 AM   #11
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,736
Re: Uneven mowing
How much do you weigh?
few resi grade mowers have a suspension to handle more than 150lbs
Old 08-01-2020, 10:12 AM   #12
Re: Uneven mowing
My last suggestion then i give up too.
Make a simple gauge to precisely check the cutting edge distance from a flat surface of each blade cutting edge. We aren't' getting much information but it really doesn't matter if your mower has 1 blade , 2 blades, 3 blades or 6 blades.
With the mower on a flat surface, ( FLAT and not necessarily level ) with all the tires inflated to specs, each blade cutting edge should only make 1 mark on a piece of Styrofoam + or - about 1/16".
The deck pic should explain blade overlap. If no overlap is the problem things are really screwed up if the mower has the correct blades. Overlap can be checked but that takes a different tool.
As you can see on my gauge why i don't loan my mowers.
Old 08-01-2020, 10:12 AM   #13
Rewards Points: 404
Re: Uneven mowing
well i am more than 150 but doesnt matter who drives it you get the same results.
Old 08-01-2020, 10:16 AM   #14
Rewards Points: 404
Re: Uneven mowing
senior citizen, i dont follow you, not sure what i am supposed to do
Old 08-01-2020, 10:22 AM   #15
Re: Uneven mowing
I just don't know how to explain it any simpler that that. The idea is to determine if each cutting edge is the same elevation from a flat surface.
You can use anything you like that a blade cutting edge would leave a mark on. Try a solid block of Styrofoam just on 1 blade edge and maybe that will give you what we're shooting for.
Edit: Edit:
