Troy Bilt TB130 Won't Get Up To Speed (sometimes) - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-14-2016, 09:54 AM   #1
Rewards Points: 64
Troy Bilt TB130 won't get up to speed (sometimes)
I bought a mower last fall (Troy-Bilt TB130), and it ran fine the few times I used it then. When I broke it back out this spring, it was having problems starting up properly– the mower would start, but the engine seemed like it wouldn't completely catch (quieter and dies if I try to push it in longer grass), and was running at a much lower level. It's done this off-and-on for the past 4 months, and once it catches and gets up to speed it's fine. It doesn't always do this, and most of the time after several tries I can get it to start properly. I've changed the oil, used new gas, and changed the air filter. Any ideas on what could be wrong? Thanks!
shan1289 is offline   Reply With Quote
Old 07-14-2016, 06:32 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,778
Re: Troy Bilt TB130 won't get up to speed (sometimes)
Ayuh,.... Sounds like there's crud in the tank, 'n carb,....
Pull the carb, take it apart, 'n Clean it,....
Old 07-14-2016, 08:19 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 228
+1 on it being a fuel problem. Also check to make sure the choke is operating properly.
lenaitch is offline   Reply With Quote
Old 07-16-2016, 12:43 PM   #4
Rewards Points: 64
So do I need to clean out the fuel tank, or just the carburetor? And is it usual to have to do something like this after having a lawnmower for less than a year? And what can I do in the future to avoid having to do this again?
Old 07-16-2016, 04:22 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 228
Possibly both but perhaps do the tank first -it's easier. The carb will take more care since it has a lot of tiny passages. You could have crud in the jet and/or fuel passage, float bowl, etc. Many new small engine carbs don't have much in the way of adjustments. You might want to check the Internet or avail yourself of a small engine repair manual that covers whatever engine Troy-Bilt uses.
It is unusual for it to crud up after one year but today's gasoline seems to be less stable. Make sure you are using fresh fuel. There is always a debate re ethanol vs. non-ethanol fuel but, either way, it has to be fresh. Did you leave last year's fuel in it over the winter? If so, did you add a fuel stabilizer? Old fuel that has had it's more volatile compounds evaporated away can end up with something that looks like shellac floating in the fuel, as well having water precipitate out of it and actually form liquid water in the tank, bowl, etc.
Old 07-16-2016, 08:33 PM   #6
Rewards Points: 64
Thanks for the response. I actually was already using a fuel stabilizer before winter, then ran the lawn mower until it was out of gas– this is part of the reason why it was so frustrating and confusing as to why the lawnmower was acting strange in the spring.
I have the engine manual for the lawnmower– I'll take a look in there and see what it says about cleaning the fuel line/carb. Fingers crossed!
Tags
engine , lawn mower , lawnmower , speed
Troy Bilt Pressure Washer Sail1094 Tractors & Mowers 0 06-09-2012 02:50 PM
Troy Bilt mower problem noquacks General DIY Discussions 11 08-03-2011 07:48 AM
troy bilt n779 pony scorpiorose52 Landscaping & Lawn Care 0 06-22-2011 04:46 PM
Troy Bilt Gas Cultivator dangier Landscaping & Lawn Care 0 05-02-2010 10:48 AM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 09:53 PM
