Toro Mower - Push Easier - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-20-2016, 03:00 PM   #1
Rewards Points: 30
I have a Toro Model 20382 self-propelled mower. Is there an adjustment that will allow the mower to push easier? The manual calls out an adjustment “Adjusting the Self-Propel Drive.” It is to increase or decrease the mower’s traction?
If I were to increase the traction, would that allow the mower to push easier? Or, is there another adjustment I could use?
Jerry
Jerry8C is offline   Reply With Quote
Old 05-20-2016, 05:08 PM   #2
Rewards Points: 107
It all depends on the belt tightness and condition. I replace mine every couple of years
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Jerry8C (05-20-2016)
Old 05-20-2016, 07:58 PM   #3
Rewards Points: 7,554
Re: Toro Mower - Push Easier
Come to think of it, my mower seems to have a weak drive. Its 13 years old. Think its time to replace the drive belt ?
Actually, I just took a look. Yep, its time.
SPS-1 is online now   Reply With Quote
Old 05-21-2016, 08:02 AM   #4
Rewards Points: 30
My mower is new (2 weeks old). So, I was wondering if I were to increase the traction, would that allow the mower to push easier? Or, is there another adjustment I could use?
Jerry
Old 05-21-2016, 02:12 PM   #5
Rewards Points: 392
Something isn't right, if it's self propelled you should not have to push at all, just controlling the machine is all you should need to do. There are usually adjustments that can be made.
rustyjames is offline   Reply With Quote
Old 05-21-2016, 07:27 PM   #6
Rewards Points: 30
Thanks for all the inputs.
Jerry
Old 06-05-2016, 11:34 AM   #7
Rewards Points: 232
I recently replaced the drive wheels on my Toro Recycler II Pro due to tire wear, the tires were worn down to the plastic. I found that the wheel bearing were shot and the inner races were turning on the axle bolt. Replacing the wheels made the mower much easier to push which is helpful for backing up.
York v45 is offline   Reply With Quote
Old 06-05-2016, 02:43 PM   #8
Rewards Points: 1,014
A lot of the newer mowers have plastic gears that mesh with another plastic gear inside the drive wheels and the plastic cogs wear out sooner than I would prefer. Fortunately they sell replacement wheels for that.
spaceman spif is offline   Reply With Quote
Old 07-07-2016, 12:54 PM   #9
samjg1's Avatar
I had a problem where I gradually lost traction on the drive wheels. I changed the drive belt which didn't help, and looked all over the Internet to see how to adjust it. I was about to either get a new mower or send it to the shop.
Then I saw the instructions in the Owners Manual. Took about 5 minutes and now works like a champ.
samjg1 is offline   Reply With Quote
Push mower runs rough, then super smooth hellohello Landscaping & Lawn Care 16 06-08-2014 03:12 PM
Push mower recommendation dinosaur1 Landscaping & Lawn Care 8 05-03-2014 07:58 PM
push mower dilemma Master Brian Landscaping & Lawn Care 6 04-17-2014 10:48 AM
TORO Lawn Mower vabear Landscaping & Lawn Care 1 09-01-2011 02:02 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
