Toro 20331 No Traction - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-12-2016, 03:50 PM   #1
samjg1's Avatar
Toro 20331 no traction
I have a Toro 20331 self propelled mower, and it gradually has lost traction to the point where the front wheels will not propel the mower. If I raise the front the wheels turn, but once they are on the ground they stop.
I've replaced the belt and it hasn't resolved the issue.
Also replaced the spark plug and air filter.
Is there a way to adjust the tension on the belt? Or is this an issue with the speed adjustment (someone told me that the mower doesn't sound like it's running fast enough).
If so, how can I adjust the speed? I always run it with the handle fully engaged.
thanks
samjg1 is offline   Reply With Quote
Old 06-13-2016, 05:32 PM   #2
Rewards Points: 1,042
Re: Toro 20331 no traction
Sounds like your drive system needs an adjustment.
Canarywood1 is offline   Reply With Quote
Old 06-13-2016, 09:02 PM   #3
Rewards Points: 7,566
Does it happen to anybody else, that you type out a reply to a post, and when you hit "Submit Reply", my reply disappears? Arg !!
Anyways, similar happened to me. Different model number, but it sure looks the same. Almost as if the cable had stretched. So at the front, where the cable attaches to a spring and the spring attaches to the steel deck ---- I drilled a new hole for the spring to mount to, a little further away. Worked fine.
SPS-1 is online now   Reply With Quote
Old 06-13-2016, 09:09 PM   #4
I remember when I bought mine, the sales literature said variable speed, so I asked the guy "how to I change the speed?".
Salesman said "Change the speed ? , you can't change the speed".
I said "it says here that this mower is variable speed"
He said "Oh, well, uh, just don't pull the engage handle as much"
You don't have a variable speed drive. Slipping the belt on the pulley will just wear out the belt faster.
Old 06-14-2016, 06:55 AM   #5
47_47's Avatar
Rewards Points: 320
Did you put an OE belt on? Usually when belts slip they are too narrow and ride too low in the pulley.
47_47 is offline   Reply With Quote
Old 06-14-2016, 10:19 AM   #6
samjg1's Avatar
I believe it was a Briggs & Stratton belt.
Old 06-14-2016, 11:25 AM   #7
47_47's Avatar
Rewards Points: 320
I would still check the belt. Engine off and have a helper engage the traction lever and look where the belt sits in the pulley. Notice the gap between the belt and the bottom of the pulley. If the belt is too narrow, it will bottom out and it will slip under a load.
Did you have the problem before you changed the belt?
I had a similar problem with an old craftsman snow blower auger. Original belt was worn and first replacement belt was too narrow and the auger slipped.
Old 06-14-2016, 02:08 PM   #8
samjg1's Avatar
I did have the problem before I changed the belt.
Your suggestion makes sense. I will try it. If the belt isn't making tight enough contact with the pulleys there would definitely be a loss of traction.
Old 07-07-2016, 01:18 PM   #9
samjg1's Avatar
I found the solution right there in the owners manual (duh!).
Thanks for the suggestions.
The Following User Says Thank You to samjg1 For This Useful Post:
47_47 (07-07-2016)
Toro Mower - Push Easier Jerry8C Tractors & Mowers 8 07-07-2016 12:54 PM
Additives for outdoor stain to aid traction on stairs? shtoink Painting 3 09-27-2012 05:20 PM
Assistance on Toro sprinkler system Dgreaney Landscaping & Lawn Care 5 06-12-2011 08:38 PM
Toro Self Pace mower, ran over pipe HELP? schuetzen Landscaping & Lawn Care 4 08-17-2009 11:15 PM
does anyone know how to replace toro 924 snowblower shear pin? tgomar Landscaping & Lawn Care 4 03-23-2009 01:53 PM
