Tilting Mower - Tractors & Mowers - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-27-2015, 11:39 AM   #16
Solidify's Avatar
Rewards Points: 834
Pole cat, thats the impression im getting; that if you can lift in that way, it will always be better than tilting it either side
Solidify is offline   Reply With Quote
Old 05-29-2015, 09:19 PM   #17
chitownken's Avatar
Rewards Points: 510
When you tip the mower on its side, the carb does not operate correctly at that angle and thus can dump excessive fuel into the intake of the engine. With the carb up, it can drain the contents of the carb bowl into the intake. With the carb down, the fuel in the tank can flow past the float and into the intake. That is what causes the black smoke. It also washes the oil off the sides of the cylinder walls which can shorten the life of the engine. You can probably get by with tipping it back (spark plug up) without draining the fuel tank, but you will most likely get some spillage out of the vent hole in the cap. If you are quick about clearing the blockage under the deck it won't be much.
As the Rooster said, continuing to do what you are doing will shorten the life of the engine.
chitownken is offline   Reply With Quote
Old 05-30-2015, 07:17 AM   #18
Solidify's Avatar
Rewards Points: 834
Ok, so I'll try to tilt my mower like this from now on:
Originally Posted by PoleCat View Post
I prop mine up against the wall of the garage with the handle on the ground and the top of the engine against the wall. Then it is at a level I can reach easier and the oil stays in the crank case.
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Trying to replace electric mower switch with normal light switch orrgroup Electrical 6 06-12-2012 05:45 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
