Testing The Charging System - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-18-2015, 07:45 AM   #1
Rewards Points: 6,236
Testing the charging system
I have a cub cadet that I have replaced the battery 3 times. Runs like a season then have to jump it to start it. Have tried taking the + cable off then touching it to the post, no spark so nothing open.
I was told the charging system is a magneto on the flywheel. Is there anyway to check to see if this is working properly.
Entering your general location can help with answering a lot of times
Old 07-18-2015, 08:08 AM   #2
Rewards Points: 392
While it's running you should have at least 13 volts at the battery.
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
ToolSeeker (07-18-2015)
Help make less confussing grounding electrode and equipment grounding? jackmel Electrical 1 01-14-2014 09:50 AM
Connecting a cable light system to a track light system megabyzus Electrical 42 11-17-2013 07:06 PM
Help finding and testing the irrigation system RyanD Landscaping & Lawn Care 10 05-29-2013 09:36 AM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 07:28 AM
Is charging a R410a system the same as a R-22 system... paulie pizza HVAC 31 06-30-2009 10:20 AM
