Squeaking Craftsman Riding Mower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-06-2018, 03:12 PM   #1
Rewards Points: 30
Squeaking Craftsman riding mower
Have A Craftsman 917.289281 ( who knew they'd fall this far!) lawn tractor with about 280hrs. Recently when I give it gas, particularly inclines or with loads, the belts squeak and the tractor either barely moves or doesn't move at all. (No squeaking when I step on the gas without the tractor moving)
I thought it'd be the belt, since there's no tension adjustment on these, so I replaced it (this is only the second time since I bought the thing). No change.
Any ideas?
I
Askin is offline   Reply With Quote
Old 09-06-2018, 10:06 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,160
Re: Squeaking Craftsman riding mower
I don't know the model but would have guessed belt as well. I tried to access the ground drive section at Sears but it wouldn't open. With no tensioner and assuming a correct replacement belt, it sounds like something has caused the distance between the two main sheaves to become shorter. Worn sheave? Dirty sheave? Loose mounting of engine or transmission causing them to shift?
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 09-07-2018, 05:43 AM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 3,986
Had a similar issue on my MTD. I replaced the belts and applied some belt dressing. Now it tuns like a champ.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is online now   Reply With Quote
Old 09-07-2018, 06:00 AM   #4
JUSTA MEMBER
Rewards Points: 4,004
Has the pulleys wore a little, and the belt is bottoming out.
As stated " Belt Dressing", can help, for now.
ED
de-nagorg is online now   Reply With Quote
Air Compressor Capacitor Help Proxima89 Tools 8 02-04-2018 09:03 PM
30" Craftsman Riding Mower Model no. 944.601380 ogbill Tractors & Mowers 1 07-31-2016 05:01 PM
30" Craftsman Riding Mower Model no. 944.601380 - removing belt ogbill Tractors & Mowers 4 06-21-2015 11:10 AM
Craftsman Riding Mower won't easily start (video) mikestorm5 Tractors & Mowers 7 08-18-2013 08:34 AM
Ariens or Craftsman Riding Mower? Osiris Landscaping & Lawn Care 3 04-20-2010 08:46 PM
