Spark Plug Tester - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-03-2017, 09:47 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
spark plug tester
When using a spark plug tester, did it after dark to get a better look, the spark is red. Shouldn't it be blue or yellow if it is getting enough fire?
I took the mower over to my daughters for her to use. It started easy. After sitting for a couple weeks, it won't start at all now.
Put in a new spark plug, no difference. Wondering if it got wet and the mag is rusted.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-04-2017, 05:29 AM   #2
Rewards Points: 202
Re: spark plug tester
Yes, blue is what you want, and, especially if you suspect that it may have gotten wet, I would start by cleaning it up a bit with either a wire brush or emery cloth. Doesn't need to be perfect. While you're in there, check the flywheel key to make sure it's not bent, and gap the coil at about the thickness of a business card.
Old 08-04-2017, 05:31 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,252
Taking DexterII's comments further, make sure the flywheel magnets and pick ups are clean. Emery cloth the contact areas and the pick up to ensure a good spark.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-04-2017, 05:47 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,614
It is my understanding that the spark "color" is a bit of a myth. Seems like the air cooled engines will show more orange in color whereas the automotive sparks will (based on the voltage type and other factors) look more "blue".
If you are seeing spark, I am going to suspect it is something else other than the magneto.
Old 08-04-2017, 05:52 AM   #5
Rewards Points: 1,506
Runs well and all of a sudden does not run at all because of yellow spark often indicates a new coil being in order. When you pull the shroud to look at the coil don't be surprised if you find a mouse nest. That's a favorite for those little fellers.
Need help with a sink plug Ethnod Plumbing 5 07-30-2014 03:53 PM
HDMI went out with spark from the plug Greg45 Electrical 6 09-12-2012 09:36 PM
77 F100 Spark Plug Socket Size? jpearson311 Automotive Repairs 10 07-10-2012 09:17 AM
Out door plug Red Squirrel Electrical 11 09-06-2009 07:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
