Snowblower Snow Melts In Garage - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 01-30-2015, 02:06 PM   #1
Solidify's Avatar
Rewards Points: 834
Snowblower Snow Melts in Garage
For those without the luxury of storing your small engine machines in a detached shed, how do you address snow that melt off your snowblower like this?
Snowblower Snow Melts in Garage-imageuploadedbydiy-chat1422648338.752824.jpg
Notice the white stain on the ground.
Solidify is offline   Reply With Quote
Old 01-30-2015, 02:50 PM   #2
Rewards Points: 1,502
http://www.grainger.com/product/TOUGH-GUY-24-Floor-Squeegee-WP119188/_/N-/Ntt-Curved+Floor+Squeegee?adgrpID=1091580731&kwdID=202 50501916&sst=subset&s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1ZBZ1_AS01?$smthumb$
SeniorSitizen is offline   Reply With Quote
Old 01-30-2015, 03:01 PM   #3
Solidify's Avatar
Rewards Points: 834
That wouldn't help; the second the snow hits the concrete it leaves a white stain because of the minerals and salt deposits. And through writing this I've realized that the only way would be to have the snow melt outside... Or on a rug of some sort.
Maybe even let the blower melt over the drain.
Old 01-30-2015, 03:27 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Move yer wood pile, 'n park the blower on that drain grate,....
Brushin', 'n cleanin' as much snow as ya can from the machine, Before ya bring it in, of course will help too,....
The white looks like road salt stains,...
Old 01-30-2015, 03:50 PM   #5
I mentioned the squeegee to remove the moisture.
Find a way to melt it outdoors and bring it in dry. Possibly under a tarp with a heat source etc. Water in the garage during cold temperatures will cause a garage atmosphere that you won't like when you see rust forming on surfaces prone to rusting. That salt on the floor will seem minor compared to the rust.
Old 01-30-2015, 04:33 PM   #6
Knows Enough to be Danger
Rewards Points: 1,215
I take a broom and broom it off before it goes inside. There's still snow on it, but 90% less
NickTheGreat is offline   Reply With Quote
Old 01-30-2015, 05:24 PM   #7
Rewards Points: 17,912
You have a water heater right next to the door that should be flushed anyway.
Hook a hose to the drain and rinse it off before bring it inside.
Old 01-30-2015, 05:58 PM   #8
Rewards Points: 6,652
You can always brush it out with an old paint brush before setting it on an old Beach Towel to help soak any water that drips off. Wipe off with a towel afterwards, to keep any metal from rusting.
Old 01-30-2015, 06:00 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 734
Park it on a washing machine pan. Cost you around $30
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Fix'n it (03-21-2015), oh'mike (03-20-2015)
Old 01-30-2015, 06:53 PM   #10
Old Bath towels are free though.
Old 01-30-2015, 07:08 PM   #11
Rewards Points: 107
My garage is a garage. It houses cars, snow blowers, lawn mowers, generators, fishing rods, camping equipment, bird seed, garbage. It's a garage with all the drippings and droppings of whatever. In my living room I care. The garage I could care less. It's a storage and utility shed
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
gregzoll (01-30-2015)
Old 01-30-2015, 07:54 PM   #12
Same here jimn01. But salts will eat away at Concrete, causing premature failure of the metal also.
Old 03-19-2015, 11:50 PM   #13
funflyer's Avatar
Rewards Points: 432
Clean, seal and wax the garage floor.
funflyer is offline   Reply With Quote
Old 03-20-2015, 07:20 AM   #14
Rewards Points: 1,602
You could epoxy the floor.
mikegp is offline   Reply With Quote
Old 04-10-2015, 12:08 AM   #15
John
JD367's Avatar
Rewards Points: 206
First, DON"T wash it off,and let it set.
Before bringing it inside,run it for 3-5 minutes,with the auger on,to shake off ,or melt any snow.
This will cut down on the dripping,and prevent the melted snow from re freezing in unheated areas.
More than one machine was damaged due to ice on a belt,pulley,auger, or chain.
Towels are the best bet,or an old rug,for catching drips.
JD367 is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
