Snowblower Manual Chute Rotator - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-09-2015, 09:08 AM   #1
Solidify's Avatar
Rewards Points: 834
I have a new Craftsman snowblower that is going through its first winter this year. My issue is that it has one of those manual turn-style chute rotators (I know, don't laugh at me, it's my first snowblower) and the indents on the chute never reach far enough to line up with the spiral on the chute rotator stick, so they don't lock in together, and therefore the chute doesn't turn when I turn the knob.
Is this something Craftsman will fix since it's new and still under warranty or is this just one of the perks of a manual turn-style rotator?
Solidify is offline   Reply With Quote
Old 02-09-2015, 09:40 AM   #2
Rewards Points: 202
Can't see it from here, and no model number to go by, so don't know if this might help, but on older ones that I am familiar with the bracket that holds the rod is slotted a bit, so that you can loosen the bolt, move the rod closer to or farther from the teeth on the chute, and tighten the bolt. Too close it binds, and too far back is probably where you are now. If this doesn't help, it's most likely covered in the manual.
Old 02-09-2015, 11:12 AM   #3
Solidify's Avatar
Rewards Points: 834
Thank you Dexter, your suggestion worked; I just brought the rotator handle closer to the slots at the base of the discharge chute and everythinf works perfectly now.Snowblower Manual Chute Rotator-imageuploadedbydiy-chat1423501930.502896.jpg
Snowblower chute clogging medman90 General DIY Discussions 26 01-30-2011 02:49 PM
Snowblower chute won't stay in position tcleve4911 General DIY Discussions 2 01-22-2011 03:28 PM
Manual D Friction Rate Worksheet kilosos2 HVAC 38 01-11-2011 04:36 PM
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 03:51 PM
Angled Laundry Chute Fox Remodeling 10 06-01-2010 11:09 AM
