Snow Shovelling Sucks - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree64Likes
Old 11-07-2019, 08:05 AM   #1
Very Stable Genius
CodeMatters's Avatar
Rewards Points: 7,986
Snow shovelling sucks
Even so, I may have gotten carried away..........lol
Snow shovelling sucks-nov-2019-021.jpg   Snow shovelling sucks-snowbowers-fall-2019-2.jpg
BigJim, SeniorSitizen and lenaitch like this.
CodeMatters is offline   Reply With Quote
Old 11-07-2019, 08:30 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,480
Re: Snow shovelling sucks
A bit....
I see a brake in the back. You a siding or window mechanic?
Old 11-07-2019, 08:42 AM   #3
Rewards Points: 6,552
That walk behind on the far right looks like it may have a digital computerized control panel.
CodeMatters likes this.
Old 11-07-2019, 08:45 AM   #4
Rewards Points: 10,824
Gotta have spares. Chances are, at least one of them will start.
SPS-1 is online now   Reply With Quote
Old 11-07-2019, 08:56 AM   #5
Very Stable Genius
Originally Posted by Windows on Wash View Post
A bit....
No, semi-retired electrician who likes to do a little of everything.
10 years ago I got a quote to do some flashing/fascia/soffit/siding
work on a rental for around 13.5k. I'd expected it to be around 3k.
Found the brake used for $650 and did the work myself. Used it
maybe a dozen times since for my own work and friends. No regrets
on that purchase.
Old 11-07-2019, 09:22 AM   #6
Rewards Points: 8,695
Since you have all the tools you can have my share of this years snow. I just want you to have fun.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 11-07-2019, 09:46 AM   #7
Rewards Points: 1,836
Make sure you clean out the insides of the drums and chutes and then use some good car spray wax on them. Especially the chute.
I have done that for a long time now and it does work pretty well. Even on the wet slushy stuff. It also works on shovels. And in the spring, do it on the underside of your lawn mower.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 11-07-2019, 09:51 AM   #8
Very Stable Genius
Thanks, I'll try that. I've been spraying them with no-stick pan spray.
No joke.
MTN REMODEL LLC likes this.
Old 11-07-2019, 10:31 AM   #9
Thing about those blowers they don't need a air filter and that makes for easy priming for cold starts with about a 1/4 tsp of gasoline dropped in the carb throat.
Old 11-07-2019, 11:45 AM   #10
No joke.
I used Pam at first, but then I got too hungry and went in
for breakfast too many times.
It does work quite well though.
@SeniorSitizen , I use ether. And an air-filter does help to keep the snow blow back out of the engine and to help warm up the air.
Old 11-07-2019, 11:58 AM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,878
No joke.
Me too....
But I lived at 7650 and only had three blowers...you're lucky.
Since then, I don't miss my three blowers....(well maybe a little bit..they were old friends)
But now, I'm having trouble keeping this damn sunshine off the decks.
MTN REMODEL LLC is offline   Reply With Quote
Old 11-07-2019, 12:57 PM   #12
JUSTA MEMBER
Rewards Points: 3,942
Sunbrella.
I am Glad that someone saw the way to get out of the long winters, that we get at over 6000 feet high.
ED
de-nagorg is offline   Reply With Quote
Old 11-07-2019, 02:20 PM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,308
Ayuh,..... This has been my preferred snow removal tool for 'bout the last 30 years,.....
Bondo is online now   Reply With Quote
Old 11-07-2019, 02:30 PM   #14
Originally Posted by MTN REMODEL LLC View Post
Me too....
Did you move Peter? Or are you still in Central Colorado?
And @De_nagorg is right, Sunbrella or similar is the way to go. I have a couple of Colorado Shade Sails I bought from Costco that are rectangular. I have them attached to my house and then to a braided stainless wire run between two boards attached to my fence. I leave them up all season long and then bring them in at seasons end. They are attached to a 1x2 at the house end for easy mounting and for wrapping the shade around when I put it away.
@Bondo , Damn Man, I am jealous. I want a tractor so bad!! I have convinced the boss that when we get actual acreage I can get one. Along with other toys. Maybe even some horses. Just a mini tractor though, but with a mower, bucket and backhoe. And maybe a few other attachments.
Old 11-07-2019, 04:32 PM   #15
Very Stable Genius
I was at the h/w store today and was going to buy the spray wax as
suggested by @ktownskier but came across Dupont Snow & Ice
Repellant and decided to give that a try.
If it works fantastically I'll let y'all know.....but hopefully I won't know
for a while........
de-nagorg likes this.
