Snapper Repower? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-18-2020, 10:48 AM   #1
Rewards Points: 6
snapper repower?
I have a snapper with the Kawasaki FX600 engine can I replace that with a B/S v twin I think they list the crank to be about 1 inch longer on the Kawi is hat a problem?
jake100 is offline   Reply With Quote
Old 05-18-2020, 11:00 AM   #2
Rewards Points: 19,008
Re: snapper repower?
That will be a big problem, and well as the wiring harness will be different.
What's wrong with the old engine?
Old 05-18-2020, 09:06 PM   #3
Rewards Points: 6
not worried about the wiring, the parts manual shows the same clutch and drive pulley for both engines, the kawi pulled a rocker stud and they kept running it on one cyl and wiped the rings and overheated it I guess smokes and burn oil like mad
Old 05-18-2020, 10:10 PM   #4
Missouri Bound's Avatar
Rewards Points: 3,626
If the PTO mounts at the end of the shaft that 1" might be an issue.
I would pull the heads and check the cylinder that had the problem.
I would think that a rebuild, if possible is a better and cheaper solution unless the cylinder has excessive damage and can't be honed.
Do you want it your way or the right way?
Old 05-18-2020, 11:11 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,299
Is it possible to space the engine back an inch to over come the 1 inch too long shaft?
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-19-2020, 08:56 AM   #6
Rewards Points: 8,717
Absolutely yes.
I had no problem finding replacement engines for a 2001 Snapper rider.
Find the tag on the engine that contains the exact model number of that engine. Then search Google:
replacement engine for <model number brand name of engine>
The mid-west suppliers had the best prices. May have been Tulsa engines.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 05-22-2020, 09:37 PM   #7
Rewards Points: 6
yea but they go for $1500 plus
