Simplicity Regent 15 W/38 Deck - Spring Placement - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By DarwinsFlinch
Old 10-15-2017, 04:16 PM   #1
Rewards Points: 56
Question
Simplicity Regent 15 w/38 Deck - Spring Placement
Hey Gang...
I came across an old Regent by the road side with "free" sign on it. Brought it home and gave it a little love - fluid change, plug, filters, grease bearings - and it fired right up. No clue why it was abandoned and not going to ask.
My question comes regarding a spring that is apparently used to tension the belt. The layout suggests to me that as the pulley is pulled left, tension on the belt increases. There is a handle on the pulley that, I assume, gets pulled right to release tension so the belt will come off the PTO pulley
I find no place to attach the spring where I think it should go. Any thoughts? Thanks in advance.
DarwinsFlinch is offline   Reply With Quote
Old 10-16-2017, 08:01 AM   #2
Rewards Points: 56
Re: Simplicity Regent 15 w/38 Deck - Spring Placement
Nevermind, all. Finally found the manual online and the belt is not routed correctly. Problem solved.
Nealtw likes this.
Tags
mower deck , simplicity , spring
Ground level deck - post placement dephtones Building & Construction 13 05-12-2013 09:14 AM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
