Simplicity Elecric Clutch - Smoking!! - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By bk10s
Old 04-21-2019, 06:51 AM   #1
Rewards Points: 36
Hello All - Please help. Replaced the drive belt on my Simplicity 1693600 Broadmoor. 18 Briggs V-Twin. PTO is locking up and smoking! I removed the electric clutch to replace the drive belt. Now, when I run the tractor without the deck on, the drive belt works fine. After about 2 minutes, with the PTO switch OFF, the electric clutch begins to heat up and gets smoking hot. Upon inspection, the bottom pulley (deck) does not spin freely. After adjustment, I start the engine again and same thing - After about 2 minutes, deck pulley begins turning and unit begins to heat up - PTO switch still off. I did not disconnect the power supply to the clutch when I removed it. What happened? Do I need to replace?
Bill
bk10s is offline   Reply With Quote
Old 04-21-2019, 02:51 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 766
Re: Simplicity Elecric Clutch - Smoking!!
It sounds like you PTO clutch is jammed and not disengaging. Try disconnecting the power to it and see what happens. It still might be jammed in the 'engaged' position.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 04-21-2019, 06:34 PM   #3
Rewards Points: 36
I disconnected the clutch and was able to operate the tractor for about an hour, pulling an aerator. At that point the clutch started to heat up and start smoking.
Old 04-21-2019, 09:33 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 766
It could still be jammed 'engaged'. Does the drive pulley turn free (engine off for safety)? It is an electromagnetic device but there are springs involved so with the power off it may still be engaged or trying to be.
Sic Itur ad Astra
Old 04-22-2019, 10:32 AM   #5
Rewards Points: 36
Yes. Drive pulley turns freely with the driveshaft.
Old 04-22-2019, 05:29 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 766
Then I'm stumped. I know basically how they work but not enough to know how to diagnose. Good luck.
Sic Itur ad Astra
Old 04-23-2019, 08:23 PM   #7
Rewards Points: 36
Replaced the clutch today and it works great! I noticed that the new clutch came with a pre-installed key-way, so I had to get rid of the single long one and go with separate key-way for the drive pulley. Thank you to all -
Bill
lenaitch likes this.
Used 1990 Simplicity 6216 vs MTD. Huskee 8 spd sparky27 Tractors & Mowers 10 02-23-2019 05:03 PM
New fan clutch to go w/ new water pump? toolaholic Automotive Repairs 3 03-13-2013 01:30 AM
General and Specific Questions on Clutch Replacement 2000 Celica GTS amodoko Automotive Repairs 24 02-25-2013 02:59 AM
'03 Honda Civic, clutch question bubbler Automotive Repairs 11 05-11-2012 10:03 PM
Quit Smoking and See What You Gain pawer judd Off Topic 13 02-07-2011 04:42 PM
