Should I Clean Again Or Replace This Carb - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By de-nagorg
Old 05-22-2017, 11:28 AM   #1
r0ckstarr's Avatar
Rewards Points: 82
Should I clean again or replace this carb
Briggs 550 series motor. I bought the mower new around 5yrs ago. It ran great for 4yrs, and always started right up. Then it got harder to start, requiring more pulls to get it running, eventually not starting at all.
Spark plug, oil, and air filter was replaced once a year.
Since I had another mower, this one sat for a few months. 2 weeks ago, I took the carburetor off, took it apart, and cleaned it. When taking it apart, the problem was obvious. The float was stuck and I could feel a gunky build-up on the parts in the bowl. I cleaned it all with carb cleaner, and put it back together. I also drained the old gas out of the tank, and filled it with new gas. For good measure, I put a new spark plug in it.
I had to use carb cleaner to get it to start up (spraying a shot or two into the carb), most likely due to having an empty float bowl. Once it started, it ran like a brand new mower again. I used it for about an hour with no issues at all. I then let it sit for a few hours to cool down and tried to start it again before putting it away. It started on the first pull.
So, I put it in the shed, where it sat for 2 weeks until I needed to use it again. Now, it won't start at all. I can make it start up by spraying a shot of carb cleaner in the spark plug hole, but it immediately dies.
I'm now thinking that maybe I should have sprayed the carb cleaner all through the gas tank and cleaned it out as well, instead of just draining it and filling with new gas.
Should I try cleaning everything again, including the tank, or replace the carb? The carb is so simple, I can't imagine it would need to be replaced, but thought I would ask.
For reference, this is the carb that my mower comes with.
http://www.homedepot.com/p/Briggs-St...3261/205884122
r0ckstarr is offline   Reply With Quote
Old 05-22-2017, 10:18 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,168
Re: Should I clean again or replace this carb
A $23 plastic carb. Brave new world. I think you are guessing correctly. The same crud that the stale fuel deposited in the carb probably did the same in the tank, and now it has likely washed into the carb again. You could try and take the tank off and swish some cleaner around in it and see what comes out. You may have to do the carb again.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
r0ckstarr (05-23-2017)
Old 05-22-2017, 10:35 PM   #3
JUSTA MEMBER
Rewards Points: 4,022
Definitely made a mistake not cleaning the tank and hose .
Varnish buildup is common if one leaves fuel in them over the winter season.
Which one feels right, spend $25+ on a new carb, and don't clean out the tank, and have it happen again, OR clean tank, fuel line, carb, and save the $25+,
ED
r0ckstarr likes this.
de-nagorg is offline   Reply With Quote
Old 05-24-2017, 07:14 AM   #4
Rewards Points: 17,912
I'd suggest replacing the fuel line, not just cleaning it, also if there's room add a fuel filter in line.
Tags
550 series , briggs , carburetor , stratton
Replace my main panel or main breaker? joe_oklahoma Electrical 16 12-15-2015 11:27 PM
Carpet FLOODED - Replace or Clean? LordX Flooring 11 07-04-2015 02:57 PM
To replace or not replace Plumber101 Appliances 1 10-21-2014 03:22 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Murray Snowblower - Carb Problems? bob6831 General DIY Discussions 7 01-15-2007 10:08 AM
