Riding Mower Issue - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree3Likes
  • 1 Post By jmon
  • 1 Post By de-nagorg
  • 1 Post By dlam9946
Old 05-05-2018, 09:10 PM   #1
Rewards Points: 162
Riding Mower Issue
I have John Deere D105 riding mower
The battery keeps draining on me. I have tried trickle charge no luck, replaced the alternator which worked for one year. As soon as the temperature dropped and I didnt disconnect the battery right away it died. The tractor is about ten years old
I replaced the battery this spring and it still wont start. Is it possible the alternator again? Or something else? I have checked all the wiring and dont see anything exposed that would cause possibly a short.
Any suggestions or thoughts would be great
Thanks in advance
dlam9946 is offline   Reply With Quote
Old 05-05-2018, 09:32 PM   #2
Rewards Points: 2,186
Re: Riding Mower Issue
Check the voltage regulator. usually mounted right on the engine block.
Sometimes they get corroded or internal short causes them to malfunction. Can be easily checked with multi-meter. At over 10 years old it may just need to be replaced.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
dlam9946 (05-05-2018)
Old 05-05-2018, 09:42 PM   #3
Maybe this utube video might help you out.
Hope you get it figured out soon dlam.
dlam9946 likes this.
Old 05-05-2018, 09:43 PM   #4
JUSTA MEMBER
Rewards Points: 4,008
You say "won't start", do you mean that it won't crank, or does it crank, but then won't start?
ED
Mike Milam likes this.
de-nagorg is online now   Reply With Quote
Old 05-05-2018, 10:01 PM   #5
Rewards Points: 162
ED
With a new battery it will crank once, then nothing. I believe I get power to the lights, I cant recall right now...
I can jump start it off my car and it turns right over
Old 05-05-2018, 10:17 PM   #6
Rewards Points: 162
Thanks for the video, will check in the morning!
jmon likes this.
Old 05-05-2018, 11:15 PM   #7
JUSTA MEMBER
Did you buy a junk battery?
Maybe a trickle charge overnight will get you mowing.
ED
Old 05-09-2018, 09:13 PM   #8
Rewards Points: 162
The voltage regulator is actually what I replaced last year. Is it possible it could have gone bad again? Possibly, but could it be something else?
The local John Deere store referred to the voltage regulator as the alternator. Sorry for the confusion
Riding Mower to replace 29 yr old John deere? onjtrainee Tractors & Mowers 20 07-21-2015 08:44 PM
30" Craftsman Riding Mower Model no. 944.601380 - removing belt ogbill Tractors & Mowers 4 06-21-2015 11:10 AM
I have a murray riding lawn mower and it wont start MSTANLEY Tractors & Mowers 14 07-30-2012 08:54 PM
Snapper riding mower problem shobri01 Landscaping & Lawn Care 4 11-15-2010 01:18 AM
Need Electrical HELP for riding mower RiceTruck Electrical 3 10-19-2010 03:24 PM
