Removing Auger Belt - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
  • 1 Post By ARB
  • 1 Post By ARB
Old 04-24-2019, 05:39 PM   #1
ARB
Rewards Points: 111
Removing Auger Belt
Hi all,
I attempted to replace the auger belt on my Snapper/Simplicity model I75246E, and was unable to remove the old belt... There is a small space between the drive shaft and the auger pulley, but it is only about half the thickness of the belt--and that's after I'm pulling up on the drive pulley to increase the space as much as I can!
There must be a trick to this but I can't figure out what it is! The operator's manual is no help, and neither is customer support at Simplicity...
I can post a pic if that would be helpful, but I'm not sure there's much to see...
Can anyone help? I'd hate to spend hundreds of dollars (including pickup and delivery) on what should be a simple and inexpensive repair!
Thanks!!!
ARB is offline   Reply With Quote
Old 04-24-2019, 05:58 PM   #2
Rewards Points: 952
Re: Removing Auger Belt
Here's what the manual says.
Maybe step 5? I don't have one so no idea what it looks like.
iamrfixit is offline   Reply With Quote
Old 04-24-2019, 06:01 PM   #3
ARB
Rewards Points: 111
Thanks for the response... Perhaps I should have mentioned that I did do that... Both levers were clamped down. Still, not even close to enough clearance... :/
Old 04-24-2019, 06:09 PM   #4
retired framer
Rewards Points: 4,616
Post a few photos.
Do not use flat bottom gables with scissor trusses.
Old 04-24-2019, 06:23 PM   #5
ARB
Rewards Points: 111
Originally Posted by Nealtw View Post
Post a few photos.
Here's the view from the bottom... The green arrow shows the gap... May be hard to tell from the photo, but it's about half the size of the width of the belt. (The auger belt is the one off the pulley, towards the bottom of the photo.)
Old 04-24-2019, 06:32 PM   #6
retired framer
Are the pulleys lined up as they should be, can you loosen a set screw an move a pulley a little?
Old 04-24-2019, 06:46 PM   #7
ARB
Rewards Points: 111
That's an interesting thought... Perhaps they're not where they should be... I'll take another look this weekend and see if I can loosen and move one or both of the pulleys… Thanks for the idea, and I'll let you know how I make out!
Old 04-24-2019, 06:54 PM   #8
retired framer
Is it like this where the drive pulley will move.
Old 04-24-2019, 06:59 PM   #9
ARB
Rewards Points: 111
It's very similar, but the drive pulley doesn't move up enough to provide adequate clearance...
Thanks for the video!
Nealtw likes this.
Old 05-04-2019, 01:43 PM   #10
ARB
Rewards Points: 111
Hey guys,
Just to let you know how I made out--and in case this helps anyone else...
I ended up detaching the auger housing, which opened up the gap so that I could pass the belt through... (According to the operator's manual, I should not have had to do this, but perhaps there's something not quite right with how my machine was assembled...)
Anyway, everything seems good to go, but the real test will be when I have some snow to throw! Thanks again, everyone, for your suggestions!
Nealtw likes this.
The Following User Says Thank You to ARB For This Useful Post:
Nealtw (05-04-2019)
Removing Shower Pan Molski Remodeling 1 02-04-2019 06:19 PM
is there a science to removing plaster? wagoner Drywall & Plaster 7 01-14-2019 10:49 PM
Best approach to removing wall tbick Building & Construction 14 05-21-2018 03:29 PM
Removing countertop wood glued to cabinets gofscooter Kitchen & Bath Remodeling 1 04-13-2017 03:26 PM
electric power auger caught in sewer pipe John1219 Plumbing 36 10-14-2014 06:32 PM
