Ransoms Xm3606 Drive Belt Inhibiting Starting - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By Bondo
Old 04-02-2017, 03:39 PM   #1
Rewards Points: 88
Ransoms xm3606 drive belt inhibiting starting
The belt from the engine to the transmission is tight enough that it's very hard to start the engine. I've had this mower for 5 years and this started two years ago. Do belts shrink? It was simple to start when I bought it. The engine shaft and the pully for the trans are stationary, they can't be adjusted that I can see.
snooger is offline   Reply With Quote
Old 04-02-2017, 05:54 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Ransoms xm3606 drive belt inhibiting starting
Ayuh,.... If That is the case, the belt has Always been tight,....
No, belts don't shrink, they only grow,....
Msradell likes this.
Old 04-03-2017, 07:12 AM   #3
Rewards Points: 88
That would be my expectation as well. I have never seen a belt shrink, but that doesn't mean it doesn't happen. I was thinking with maybe wet grass or something like that over time it was possible. Starts first pull with that belt off but put the belt on and I can't pull it hard enough to get it to turn over.
I'm getting a new belt regardless this one does show a bit of wear. I might even opt for another 1/16 of an inch larger just to give me a bit more slack.
Old 04-03-2017, 08:40 AM   #4
Bondo's Avatar
Ayuh,... What yer explainin' makes No sense, at All,....
Either the belt is part of a clutch system, 'n should be loose, or it's supposed to be a tight belt,...
If it's supposed to be a tight belt, the transmission isn't goin' into neutral properly,....
Old 04-03-2017, 09:02 AM   #5
Rewards Points: 88
The belt is supposed to be loose. It has a tensioner pully that engages the belt to tighten it up when drive is engaged. However, the belt is not very loose when the tensioner is not engaged - it's actually hard to take off the pulleys (but I can get it off).
If the transmission isn't going into neutral properly, I'd almost think the weels would turn as the engine turns over. That doesn't happen however.
I appreciate the advice. I agree, it's not making a lot of sense to me either. Either I'm missing something fundamental or just not explaining it right. Figured you guys on here would give me something to think about. I think my next step is to have my son stop by while I have it lifted and I can pull on it and he can watch to see if that transmission pulley is turning. Maybe it's turning hard (due to some problem with the transmission when in neutral).
Thank you.
Murray 10/30 drive belt problem 68joecool Landscaping & Lawn Care 3 06-28-2011 07:16 PM
Sears belt drive 1/2 hp garage door opener pcampbell Appliances 4 03-27-2011 10:44 AM
seeking rubber sleeve for belt sander drive roller orkraider Tools 0 03-17-2010 09:39 AM
Belt care... RippySkippy Tools 3 12-25-2008 01:43 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 03:14 PM
