Premix Fuel For Blower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-27-2015, 10:17 AM   #1
Rewards Points: 2,420
Premix fuel for blower
I have a cheap 2 cycle Ryobi gas blower that I bought may be six months ago for I don't remember $119 or $139...
Used in a few times and let it sit for about 2 months of non-use. I started it up and it will start, then I am supposed to switch to "HALF" to restart it, wait 10 seconds and switch to "FULL". It will start in HALF, but when I waited 10 seconds and switch to "FULL" position it will run for another 20 seconds or so and quit.
The fuel I used is the standard unleaded gasoline 1 gallon mixed with that small bottle of stuff that comes with it. Didn't have any problem the first few months.
So I opened the fuel cap, and drained all of the fuel in it. I then bought a can of the PREMIX fuel from the store and poured that in, and it started and worked just fine, switched to FULL and didn't quit anymore.
Why? Is the fuel I mixed gone "stale"? Did I not mix it right? Or the premix stuff is just better?
miamicuse is online now   Reply With Quote
Old 08-27-2015, 11:15 AM   #2
Rewards Points: 190
Ethanol in the fuel picks up moisture and makes it go bad. You can add fuel stabilizer or buy the premix.
Dan
djlandkpl is offline   Reply With Quote
Old 08-27-2015, 11:47 AM   #3
47_47's Avatar
Rewards Points: 320
You are choking the engine in full. After you let it run at half choke to let it warm up a little, turn the choke off.
47_47 is offline   Reply With Quote
Old 08-27-2015, 08:48 PM   #4
Rewards Points: 996
premix, isn't that stuff like $15 a gallon. i have no problems mixing my own.
Fix'n it is offline   Reply With Quote
small engine fuel filter recommendations gunner666 Landscaping & Lawn Care 2 07-30-2014 10:17 PM
Fuel line repair Hardway Automotive Repairs 31 09-30-2013 08:15 AM
villager missing on cylinder 5 Bigplanz Automotive Repairs 22 08-04-2013 07:32 PM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 08:57 PM
Feather lite weedeater trimmer wont start after changing fuel line! jamjr74 Tractors & Mowers 2 05-12-2012 08:20 AM
