Poulan Pro 54 Inch Won't Start - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-13-2015, 03:31 PM   #1
Poulan pro 54 inch won't start
Hi I have a newer poulan pro briggs and straton engine ride on.
Before the winter I change the plugs and oil and put stabilizer in my gas and let it run for a few minutes. I made sure to grease all the nipples .
I tried starting it for the first time since it's hibernation
I don't remove the battery but I just charge it on the first usage. This year she wouldn't start. I turn the key and the dash with the amount of used hrs. Comes up. I hear a faint clicking sound but it won't crank over. I tried putting some gas in the plug to kick start it
It sounded like a backfire but still didn't start.
It's weird I've never had this issue before.
Sent from my SM-N900W8 using diychatroom.com mobile app
chillz911 is offline   Reply With Quote
Old 04-13-2015, 03:51 PM   #2
ZTMAN's Avatar
Rewards Points: 276
First of all, never put grease on nipples, that's what zerks are for. I get irritated when someone tries to grease my nipples. My guess is you have a bad cell in your battery and it wont take a charge. Pop out the battery, get it tested.
ZTMAN is offline   Reply With Quote
Old 04-13-2015, 05:29 PM   #3
Rewards Points: 17,884
Got a meter that checks DC voltage?
Cleaned the battery terminals?
Tried jumping it off the car or truck battery?
Old 04-13-2015, 05:31 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Yes, if it doesn't turn over but it is clear there is some power and especially hearing the click (likely from a solenoid) get the battery tested.
Now, if it is s 12 volt battery you can jump start the tractor using your car battery.
Old 04-14-2015, 08:35 AM   #5
Thanks I'll try that
Old 04-18-2015, 02:25 PM   #6
Dc voltage read 11.25 v. I charged the battery again. Still no luck I noticed that it tries to turn ...maybe 3 or 4 times and that is it.it clearly isn't firing.
Old 04-18-2015, 03:25 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,226
Ayuh,.... That battery is Dead,....
Old 04-18-2015, 08:56 PM   #8
Should I try jumping it with the car battery?
Old 04-18-2015, 10:55 PM   #9
Rewards Points: 1,910
Either that or with a charger/starter (everyone should have one). It sounds like your battery just isn't putting out enough amps.
Old 04-18-2015, 11:35 PM   #10
John
JD367's Avatar
Rewards Points: 206
Most lawn tractors come with the cheapest battery the manufacturer can get.
Add to this,the fact that most tractors/equipment sit in a dealership,or store for up to a year,before being sold,and you will have battery problems.
Also,stores,unlike dealerships,aren't known for doing proper "set up".They simply bolt them together,and put them on display. They don't level decks,or grease them,etc.
A friend of mine bought a Husqvarna from Home Depot,last year,and never got to use it, because the engine seized,when they were unloading it. The people at the store,didn't put oil in it..... just pushed it onto a trailer,and "delivered" it !
One of my customers brought in a new Troy Bilt with damage to the deck. Seems the store didn't put the pins in the deck lift arms,and it dropped at the rear,and the blade smacked something,and broke the mandrel.
My advice: When buying from a store,double check EVERYTHING !
JD367 is offline   Reply With Quote
Old 04-19-2015, 07:21 AM   #11
Rewards Points: 392
If you do don't have the engine running, and use best practices when doing it.
rustyjames is offline   Reply With Quote
Old 04-19-2015, 08:27 PM   #12
I tried without the engine running and nothing happend and it wouldn't turn over. I started the car and was able to fire the tractor. It ran no problem for about 15 minutes or so. I parked it back in the shed and tried to restart it and no luck. So I guess I will have to get a new battery
Old 04-23-2015, 11:53 PM   #13
A Little Of Everything
Rewards Points: 1,414
Sure. Jump start it to get it running. But you're going to need to replace the battery. Most lawn equipment batteries are designed to run for MAYBE 2 years. Often they only last 1.
Clean your battery cables good, and replace the bolts on the battery cables with stainless steel bolts & nuts.
DrHicks is offline   Reply With Quote
new pergo - where to start laying first course snowninja Flooring 4 09-25-2010 04:47 PM
60 year old duct system with 4 inch ducts kjseattle HVAC 5 06-27-2009 09:08 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 10:20 PM
