Old Honda HRZ Mower, Over/under Revving - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-20-2018, 11:09 AM   #1
Rewards Points: 34
Old Honda HRZ mower, over/under revving
Hello,
I have an old Honda HRZ mower that I've recently replaced the carburetor, and throttle control cable on.
I'm having running problems that have a distinct pattern , after installed the new carb. On cold start, the mower starts up and runs OK, but with a high RPM that's difficult to tame down. The self-propel will also work for a short time.
Then, just after the engine warms up, it's starts revving up and down and sounds like it will die, which it sometimes does, but mostly it will just keep running like that. The self-propel won't work hardly at all at this point, which makes mowing exhausting.
I'm thinking this may have something to do with the governor, but not sure how to check/adjust. I've played around with that spring on it before, but the governor lever doesn't appear to have much range of movement. I noticed with the spring from carb to governor disconnected, the mower runs about the same?
Thanks for any ideas on this.
berniemyboy is offline   Reply With Quote
Old 06-20-2018, 11:19 AM   #2
Rewards Points: 34
Re: Old Honda HRZ mower, over/under revving
After reading some other posts, I think I should mention that I adjusted the throttle stop spring on the new carb to get it running at a high enough RPM when I installed the new carb. I've read this can cause problems with the governor. I think I might try to adjust it back down, but then the engine may not run at all, or not at near high enough RPM.
Old 06-23-2018, 07:57 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,..... It sounds like yer carb rebuild, failed,....
Bondo is online now   Reply With Quote
Toro Personal Pace Self-propelled mower - engine revving up and down joemc3 Tractors & Mowers 11 05-13-2018 05:43 PM
Buying a used honda mower - need help! marcus118 Landscaping & Lawn Care 7 04-15-2013 10:51 AM
Honda 160cm3 self prop. lawn mower dies notahandyman Landscaping & Lawn Care 4 09-28-2010 09:12 PM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
honda hrr216tda mower ohlawnmower Landscaping & Lawn Care 1 07-27-2010 06:00 AM
