New Life In Lawn Tractor - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree5Likes
  • 2 Post By nauti1
  • 3 Post By lenaitch
Old 03-03-2018, 09:40 AM   #1
nauti1's Avatar
Rewards Points: 6
New Life in Lawn Tractor
I've had a Simplicity 20 HP Broadmoor lawn tractor since 2005. The last few years it would get progressively "weaker", even having trouble going up slopes. Tuning & servicing didn't help. It would be OK when first using it, but would die off after a while, and backing up was shameful. It takes 2-3 hours to mow my lawn, even with a 44" deck, so it became very frustrating. I finally decided last summer to really look at "everything" myself rather than have it serviced again.
I crawled under the tractor & started at the front & worked back. Nothing out of the ordinary until I got back to the transmission, which was tucked up high, basically out of normal sight. The cooling fins were loaded with grass clippings, old stuff that had accumulated over the years. I removed the grass from the cooling fins. Voila! Immediate change! It's obvious now how effective the cooling fins were in keeping the transmission oil (?). I now bow off the fins after every use with my leaf blower, despite it being difficult to access them.
I could not believe the change. Back in business. The old 20 horses are pulling again.
Dave Sal and CodeMatters like this.
nauti1 is offline   Reply With Quote
Old 03-03-2018, 10:26 AM   #2
Rewards Points: 17,912
Re: New Life in Lawn Tractor
When's the last time the hydraulic drive belt was changed?
Old 03-03-2018, 10:33 AM   #3
CodeMatters's Avatar
Rewards Points: 6,638
Interesting. I was guessing fuel flow problem. Thanks for sharing that.
CodeMatters is online now   Reply With Quote
Old 03-03-2018, 10:43 AM   #4
Rewards Points: 1,550
QUOTE: It would be OK when first using it, but would die off after a while, and backing up was shameful.
Time and heat was the clue.
Old 03-03-2018, 08:37 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,208
If it has gotten so hot to affect performance you might want to think about changing the transmission fluid. It sounds like a hydrostatic transmission, but either way, not a bad idea.
Msradell, Dave Sal and de-nagorg like this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Terra Grips Lawn Tractor Tire Chains/Grips Reviews vestaviascott Landscaping & Lawn Care 15 07-30-2015 10:30 AM
Lawn Tractor Has No Power Smoke Tractors & Mowers 10 04-07-2012 11:52 AM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
Lawn tractor transmission oil? redline Landscaping & Lawn Care 6 07-13-2008 05:49 PM
