Need Help With Snowblower Carb Issue - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree3Likes
  • 3 Post By CodeMatters
Old 01-22-2020, 12:58 PM   #1
Rewards Points: 34
Need help with snowblower carb issue
I'm trying to get my snowblower working (Poulan Pro PR100) by first cleaning the carburetor. On top of the carb there is a black plastic screw (see pictures). It screws into the metal housing but there is nothing attached to it. What does it do? It it supposed to be adjusted to partially obstruct the opening in the red part directly below? If so, how do I determine how to adjust? There is a small gap between the screw and the red part, so I don't see how moving the screw makes any difference. Thanks.
Need help with snowblower carb issue-blackscrew1.jpg   Need help with snowblower carb issue-blackscrew2.jpg
Cameron Davis is offline   Reply With Quote
Old 01-22-2020, 01:45 PM   #2
CodeMatters's Avatar
Rewards Points: 7,462
Re: Need help with snowblower carb issue
Not sure....does the blk plastic screw protrude out the other side of the
metal it screws into? If so it looks like it could be a min throttle stop.
CodeMatters is offline   Reply With Quote
Old 01-22-2020, 02:20 PM   #3
Rewards Points: 3,536
According to the manual is the red button the primer?
Old 01-22-2020, 03:38 PM   #4
Idle stop screw. See 6:30 of video.
Bondo, Dave Sal and lenaitch like this.
