My Rider Just Died, Help? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree9Likes
Old 07-15-2018, 10:09 PM   #1
i carved this sword
feralfreak's Avatar
Rewards Points: 161
My rider just died, help?
I was skidding some disc'd up soil so I can get grass growing and mow it (before I could not mow it, it was plowed and a local person disc'd it up for me), i was doing it with a John deere 125 riding mower and a pallet with 3 cinder blocks, but before that, and hour before it died, i changed the fuel filter, when it died it acted like it ran out of gas but just minutes before I put more in, ao it had almost half a tank, and I tried to start it back up and i heard it making that initial noise but it wouldn't turn over, i waited about 2 or 3 hours and tried it again, it almost turned over but it died,tried again and it just made that initial noise, i tried adjusting the choke and nothing, what could be wrong?
feralfreak is offline   Reply With Quote
Old 07-16-2018, 04:01 AM   #2
Rewards Points: 1,251
Re: My rider just died, help?
How's the oil level?
KHouse75 is offline   Reply With Quote
Old 07-16-2018, 07:56 AM   #3
Rewards Points: 2,122
Fresh or old fuel being used ?
MTN REMODEL LLC likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 07-16-2018, 09:38 AM   #4
HDS
Rewards Points: 318
Does it turn over at all and just not catch? Can try putting some starter fluid in and seeing if it'll start for a few seconds that way. Will tell you if you have a fuel delivery problem.
Just an FYI, your JD is probably not rated for ground engagement and I would be wary of overdoing it on your transmission especially if you have any hills.
Dave Sal likes this.
HDS is offline   Reply With Quote
Old 07-16-2018, 09:46 AM   #5
i carved this sword
feralfreak's Avatar
Rewards Points: 161
The oil is full, the fuel is fresh, ill have to see what starter fluid is, i think i heard of it before, my uncle has a friend who knows a lot about these things and asked him, he said it could be a bad pump or vacuum tube, fortunately if its the pump that is fairly cheap, normally i just mow with it, or pull a little trailer if i need to get dirt to fill dog holes (that mutt better not let me catch him digging )and a trench a mutt dug in our hillside, didn't know until I was riding down it, was lucky nothing happened
Old 07-16-2018, 01:44 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 100
What is the "initial noise"? Can you get a wrench on the flywheel to see if you can rotate the engine?
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 07-16-2018, 02:51 PM   #7
Rewards Points: 50
to late in the season for grass. wait till fall
hankdiy is offline   Reply With Quote
Old 07-16-2018, 06:56 PM   #8
Dave Sal's Avatar
Rewards Points: 1,440
I second the suggestion to try some starting fluid. If my mower fails to start, I pop off the air filter and give a quick spray of starting fluid directly into the carburetor. Usually fires right up.
Last year my mower died and even the starting fluid did not get it to start. Had no spark, and turned out that the ignition coil died. A replacement from Amazon was about $30 and she runs like new.
Dave Sal is offline   Reply With Quote
Old 07-17-2018, 12:12 AM   #9
i carved this sword
feralfreak's Avatar
Rewards Points: 161
Im not sure how to describe the initial noise, just what you expect to hear before it turns over.
I'll have to ask my uncle if he has starter fluid, im curious what it does that fires up an engine, the science/mechanisms of things fascinate me,
With grass, what makes the fall better?
Ill have to look up the ignition coil, fortunately the pump is cheap, 27 with tax, i was afraid it was gonna be 50 - 60 bucks, we already have to put off some fixes for when money is more available (moms laptop screen, which I already replaced a month ago, she wont lower the screen with earbuds on the keyboard again) and put off getting parts for an invention printed, oh well, hopefully the fuel pump replacement will solve my problem, ive noticed it was harder to start before, the uncle things it might have been fixing to fail and changing the filter released a vacuum it was needing or something
Old 07-17-2018, 08:00 AM   #10
Rewards Points: 7,261
It is more explosive than gasoline. Use it sparingly.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 07-17-2018, 08:21 AM   #11
Rewards Points: 946
Starting fluid can be expensive. It can be explosive, it can wash the oil off the cylinders. Try silicone spray.
fireguy is offline   Reply With Quote
Old 07-17-2018, 08:26 AM   #12
Rewards Points: 2,304
There's sure a lot of expensive guessing going on here.
Drachenfire likes this.
Old 07-17-2018, 02:07 PM   #13
Usually Confused
lenaitch's Avatar
Rewards Points: 100
All of the usual testing for f and spark plus trying starting fluid won't mean a whole lot until the OP can get the engine to turn over. If it won't turn over on a good battery or jumper cables then there might be a problem with the start switch or solenoid. This assumes the engine is actually free to rotate.
Sic Itur at Astra
Old 07-18-2018, 08:50 PM   #14
i carved this sword
feralfreak's Avatar
Rewards Points: 161
I made a video, after we bought the new fuel pump, havent installed it, we tested the pump already on(he regretted not remembering that test before ) and its moving gas good, https://youtu.be/DQw2In_LDgE
Old 07-18-2018, 09:25 PM   #15
Usually Confused
lenaitch's Avatar
Rewards Points: 100
Well you have fuel and the engine turns over. The strength of a spark can be pretty subjective. How did your friend test it? What was the colour of the spark? It could any of: old plugs, old wires, failing coil(s). You also might try cleaning up the connections on both the primary and secondary (plug) side of the coil circuit. The battery connection looks a little corroded over and other connections might be the same.
Have you checked to see if you have compression in both cylinders?
Sic Itur at Astra
Rider suggestions algored2deth Tractors & Mowers 25 08-25-2013 02:13 PM
Hedge died anthony.donnell Gardening Forum 3 12-20-2012 02:55 PM
My furnace died BobPike HVAC 18 12-01-2011 09:42 PM
Help! Two outlets died at the same time. MindOfVacuity Electrical 2 06-19-2010 04:46 PM
