DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Tractors & Mowers (https://www.diychatroom.com/f106/)
-   -   My rider just died, help? (https://www.diychatroom.com/f106/my-rider-just-died-help-636075/)
feralfreak 07-15-2018 10:09 PM
I was skidding some disc'd up soil so I can get grass growing and mow it (before I could not mow it, it was plowed and a local person disc'd it up for me), i was doing it with a John deere 125 riding mower and a pallet with 3 cinder blocks, but before that, and hour before it died, i changed the fuel filter, when it died it acted like it ran out of gas but just minutes before I put more in, ao it had almost half a tank, and I tried to start it back up and i heard it making that initial noise but it wouldn't turn over, i waited about 2 or 3 hours and tried it again, it almost turned over but it died,tried again and it just made that initial noise, i tried adjusting the choke and nothing, what could be wrong?
KHouse75 07-16-2018 04:01 AM
Re: My rider just died, help?
How's the oil level?
Gregsoldtruck79 07-16-2018 07:56 AM
Fresh or old fuel being used ?
HDS 07-16-2018 09:38 AM
Does it turn over at all and just not catch? Can try putting some starter fluid in and seeing if it'll start for a few seconds that way. Will tell you if you have a fuel delivery problem.
Just an FYI, your JD is probably not rated for ground engagement and I would be wary of overdoing it on your transmission especially if you have any hills.
feralfreak 07-16-2018 09:46 AM
45 Attachment(s)
The oil is full, the fuel is fresh, ill have to see what starter fluid is, i think i heard of it before, my uncle has a friend who knows a lot about these things and asked him, he said it could be a bad pump or vacuum tube, fortunately if its the pump that is fairly cheap, normally i just mow with it, or pull a little trailer if i need to get dirt to fill dog holes (that mutt better not let me catch him digging )and a trench a mutt dug in our hillside, didn't know until I was riding down it, was lucky nothing happened
lenaitch 07-16-2018 01:44 PM
What is the "initial noise"? Can you get a wrench on the flywheel to see if you can rotate the engine?
hankdiy 07-16-2018 02:51 PM
to late in the season for grass. wait till fall
Dave Sal 07-16-2018 06:56 PM
1 Attachment(s)
I second the suggestion to try some starting fluid. If my mower fails to start, I pop off the air filter and give a quick spray of starting fluid directly into the carburetor. Usually fires right up.
Last year my mower died and even the starting fluid did not get it to start. Had no spark, and turned out that the ignition coil died. A replacement from Amazon was about $30 and she runs like new.
feralfreak 07-17-2018 12:12 AM
45 Attachment(s)
Im not sure how to describe the initial noise, just what you expect to hear before it turns over.
I'll have to ask my uncle if he has starter fluid, im curious what it does that fires up an engine, the science/mechanisms of things fascinate me,
With grass, what makes the fall better?
Ill have to look up the ignition coil, fortunately the pump is cheap, 27 with tax, i was afraid it was gonna be 50 - 60 bucks, we already have to put off some fixes for when money is more available (moms laptop screen, which I already replaced a month ago, she wont lower the screen with earbuds on the keyboard again) and put off getting parts for an invention printed, oh well, hopefully the fuel pump replacement will solve my problem, ive noticed it was harder to start before, the uncle things it might have been fixing to fail and changing the filter released a vacuum it was needing or something
Colbyt 07-17-2018 08:00 AM
It is more explosive than gasoline. Use it sparingly.
fireguy 07-17-2018 08:21 AM
Starting fluid can be expensive. It can be explosive, it can wash the oil off the cylinders. Try silicone spray.
SeniorSitizen 07-17-2018 08:26 AM
There's sure a lot of expensive guessing going on here.:vs_laugh:
lenaitch 07-17-2018 02:07 PM
All of the usual testing for f and spark plus trying starting fluid won't mean a whole lot until the OP can get the engine to turn over. If it won't turn over on a good battery or jumper cables then there might be a problem with the start switch or solenoid. This assumes the engine is actually free to rotate.
feralfreak 07-18-2018 08:50 PM
I made a video, after we bought the new fuel pump, havent installed it, we tested the pump already on(he regretted not remembering that test before ) and its moving gas good, https://youtu.be/DQw2In_LDgE
lenaitch 07-18-2018 09:25 PM
Well you have fuel and the engine turns over. The strength of a spark can be pretty subjective. How did your friend test it? What was the colour of the spark? It could any of: old plugs, old wires, failing coil(s). You also might try cleaning up the connections on both the primary and secondary (plug) side of the coil circuit. The battery connection looks a little corroded over and other connections might be the same.
Have you checked to see if you have compression in both cylinders?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
