Mulcher Blade - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-22-2016, 02:20 PM   #1
Rewards Points: 168
Mulcher Blade
Will simply putting a mulching blade on a standard walk-behind mower make it a "mulching mower" and eliminate my need for a bag if mowed properly?
giddyap is offline   Reply With Quote
Old 09-22-2016, 03:59 PM   #2
Rewards Points: 1,042
Re: Mulcher Blade
I don't know what "mowed properly" means,but when a mower has a mulching blade on, there's usually a baffle covering the discharge chute.
Canarywood1 is offline   Reply With Quote
Old 09-22-2016, 07:44 PM   #3
Rewards Points: 996
Re: Mulcher Blade
if you use a bag, then the side discharge should already be blocked.
i recently put a GATOR BLADE on my toro (that had the factory mulching blade).
it made a large difference in how well it mulched the grasss. i used to get "rows" of cut grass. pretty much not any more. if you have leaves that are not made of leather, like mine, then it will mulch those a lot better also.
only thing with the GATOR = you have to be very carefull installing it.
Fix'n it is offline   Reply With Quote
Old 09-28-2016, 12:09 PM   #4
Rewards Points: 168
Re: Mulcher Blade
By properly I mean frequently enough and at the right height. Otherwise, even a great mulcher wont do a very good job if the grass is too long.
Old 09-28-2016, 12:10 PM   #5
Rewards Points: 168
Re: Mulcher Blade
With my bag off the rear door is closed.
On the side, there is a door that can come off, although Ive never removed it.
Old 09-28-2016, 12:16 PM   #6
Rewards Points: 4,170
Re: Mulcher Blade
Yes, it sounds like your mower will mulch with the proper blade if you do not attach the bag to the rear.
stick\shift is offline   Reply With Quote
Old 09-28-2016, 03:54 PM   #7
Rewards Points: 202
Re: Mulcher Blade
I agree, sounds like it is designed with the option of mulching, and I doubt that there is much difference in the cost of the blade, so I would definitely give it a shot. I've seen mixed results, some mulching mowers do a good job and some not so impressive, but my personal experience has been very good. I bought my Toro rider in the spring of 1995, bought their recycling kit, which included different blades and a few shrouds, a couple of years later, and it has taken care of the clippings as well as the leaves ever since. In fact I had intended to buy a new Ferris this past spring, but put it off, deciding to baby this one along as far as it will go, primarily because of the quality job it still does, both cutting and mulching. And as far as what you might hear about mulching leaves (I've heard some say that it's not good for the lawn), that's what I have been doing, and have not seen any negative effect.
Old 09-29-2016, 08:02 AM   #8
Rewards Points: 7,009
Re: Mulcher Blade
Engine size, height of grass and the water content of the grass all factor into it.
My 9 HP rider always loafed along mowing the yard. Spring grass, a day or two late mowing and it works the snot out of that engine.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-04-2016, 10:13 PM   #9
A Little Of Everything
Rewards Points: 1,418
Re: Mulcher Blade
An aggressive mulching blade will make a big difference, and it sounds like your mower is designed for that option.
What I found in my years of lawn-care was that mulching "properly" was extremely difficult. The conditions have to be ideal (dry) and you can only cut about 1/2 inch of grass - otherwise it just bunches up.
DrHicks is offline   Reply With Quote
Old 10-05-2016, 02:49 PM   #10
Re: Mulcher Blade
If i could only cut a 1/2 inch, i'd have to mow every other day.
Old 10-05-2016, 10:51 PM   #11
Re: Mulcher Blade
Right. And that's exactly the problem we ran into. It's a nice idea, but it's only feasible for a select few people.
Now I did exaggerate that half-inch a little bit. But note that, in order to cut more than that, all the other conditions would have to be ideal And usually they're not - especially if you're mowing commercially.
Miter saw issues - cracked blade? LanterDan Tools 10 04-17-2015 07:06 PM
Circular Saw - Blade Plug Problem ejseidman Tools 7 10-01-2012 01:04 PM
How many Tooth Saw Blade for Trim? HandyFrank Carpentry 11 12-28-2011 07:11 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
