Mower Suddenly Running Rough - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree4Likes
  • 4 Post By chiraldude
Old 05-11-2019, 05:27 PM   #1
Rewards Points: 616
Mower suddenly running rough
I had an Airens lawn mower for 18 years and had not a single problem with it. Bought a new one a few years ago and starting on its 3rd season. Today it started up great and about 5 minutes into mowing the engine started running rough, idle is up and down and up and down.....
Usually this points to the carb needing cleaning doesn't it, but would that cause it to instantly start running rough? Any ideas on this?
Photo in attachment. Inline photos no longer work here it appears.
Thanks.
Richo is offline   Reply With Quote
Old 05-11-2019, 05:58 PM   #2
Rewards Points: 917
Re: Mower suddenly running rough
Sounds like some crud came loose and made its way to the jet or some port somewhere.
As you say, first thing to do is pull the carb, disassemble and blast with carb cleaner.
Also check that fuel if flowing through the filter and lines.
chiraldude is offline   Reply With Quote
Old 05-11-2019, 06:17 PM   #3
Rewards Points: 8,526
Another thing to check is the choke. Does it have trouble starting when hot? On many mower engines today, there is a butterfly choke plate in the carburetor area, and a metal clock-type actuator on the other side of the engine at the exhaust, with a piece of coat-hanger sized wire linking the two. I have had my mower start running rough, and after a bit of examination, noticed the link rod was missing --- choke always on.
SPS-1 is online now   Reply With Quote
Old 05-12-2019, 08:41 AM   #4
Rewards Points: 616
There are no problems when starting it, hot or cold.
I persisted and ran the thing, used the throttle a couple times to rev it higher, and strangely enough it suddenly started running fine again and did through the rest of the lawn.
So does it sound like something got into the fuel system and worked its way out?
Old 05-12-2019, 10:24 AM   #5
Rewards Points: 917
Maybe inspect/replace the fuel line? Fuel filter won't do any good if the downstream hose is disintegrating.
Old 05-12-2019, 11:09 AM   #6
Rewards Points: 7,327
On a Briggs I would replace the diaphragm. Yours looks like a gravity carb. Probably cost $15 for a new carb or $30 for a kit. That should not be a hard choice.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-12-2019, 01:25 PM   #7
Rewards Points: 616
Are any of these things mentioned (bad hose, bad carb) something you would expect to happen on a mower only in its 3rd season?
The last Ariens mower had a Centura engine, but this one has a Kawasaki.
I use only ethanol free gas in the mower.
Old 05-12-2019, 03:10 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 266
I have a Kawasaki engine in my 30+ year old JD tractor and they are pretty solid (back then anyway). There are too many factors to say it is a problem with a new engine. Fresh gas? Clean container? Debris in retailer's tank? Etc. etc.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Crawl space - bottom of 2"x4" running board flush with bottom of floor joist joemc3 Electrical 6 03-19-2018 12:01 AM
Pool Motors suddenly stopped running dennis90 Electrical 2 07-07-2017 02:05 PM
Safety w/ Welding Under Mower Deck with Gasoline in Plastic Tank amodoko Safety 5 07-04-2016 02:45 PM
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 05:42 PM
Lawn mower starts then dies gazz87 Landscaping & Lawn Care 8 11-19-2011 02:43 PM
