Mower Noise - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 03-10-2014, 11:56 AM   #1
Rewards Points: 896
Mower noise
I'm probably lucky this is my worst problem. I'd like to go one yr with no mower trouble!!!😟
This is a recycling Toro walk behind mower. 2 yrs old.
I hit a water meter and it stopped the mower. There's only a tiny PC of corner chipped off the blade and that's no problem cause Ive had worse.
Anyway, I restarted the mower an now it sounds like the throttle is running faster. Could that happen? What do I do? I still remember how often my dad yelled " slow down, you'll burn up the engine".
Startingover is offline   Reply With Quote
Old 03-10-2014, 12:15 PM   #2
Rewards Points: 17,912
Lawn mower are made to run wide open when mowing.
Startingover (03-10-2014)
Old 03-10-2014, 12:19 PM   #3
bbo
blade could be(most likely is) unbalanced now.
new blade or have someone ( or yourself) sharpen and balance.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 03-10-2014, 12:22 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
possibly knocked out the governor speed adjustment?it usually won't change from a ''hit'' but if there was a loose screw it may have
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 03-10-2014, 12:24 PM   #5
Rewards Points: 896
Ok,
What's going to happen if I keep using it as is until it just stops running? I don't like the man at the mower repair shop and I have to switch cars with my daughter to even take it to a shop. It's all a pia.
What's the life span of a mower?
Old 03-10-2014, 12:29 PM   #6
life of a mower?10sec-30 years depending on how it's taken care of
if it's truly ''over reving''it won't last long and could be dangerous..
Old 03-29-2014, 11:15 PM   #7
Rewards Points: 896
Just got my mower back from shop. Good thing I took it in.
They showed me the old blade. One side one completely bent from hitting that steel city water pipe. That's why it felt different afterwards.
Old 03-30-2014, 05:38 AM   #8
Rewards Points: 1,550
You're lucky. It's not unusual for the flywheel key to shear and or a bent crankshaft when an object is hit hard enough to stop the engine. Maybe that mower is Toro tuff.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Startingover (03-31-2014)
Old 03-30-2014, 10:10 AM   #9
Retired Moderator
Rewards Points: 7,174
In the future---replacing a blade is not advanced mechanic work--
That is also the time to change the oil---when that day comes--start a thread---most of us have done that task many times.
My yard is over a gravel bed (ancient glaciers) and clobbering rocks is common---so blade changing is done all to often---
Rattling Noise from Roof when windy drgillian Roofing/Siding 6 10-17-2018 07:35 AM
Condenser fan noise and then blade breaks. whotheguy HVAC 11 09-30-2013 07:59 PM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
