Loose Blade - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree6Likes
  • 3 Post By joecaption
  • 1 Post By Rough Rooster
  • 1 Post By Johnny_inFL
Old 04-09-2019, 06:55 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Loose blade
I have a good running push mower and all of a sudden the blade won't stay tight. I even tightened it with an impact. Any ideas? Maybe Loctite? Another lock washer?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-09-2019, 07:05 PM   #2
Rewards Points: 18,376
Re: Loose blade
100 % sure it's not bent from hitting something?
Checked to see if it's balanced?
https://www.walmart.com/ip/Blade-Bal...hoCSzMQAvD_BwE
Tried replacing the bolt with a new grade 8 bolt?
de-nagorg, Drachenfire and mark sr like this.
Old 04-09-2019, 11:00 PM   #3
JUSTA MEMBER
Rewards Points: 1,500
Re: Loose blade
Yes , inspect that blade carefully, any imperfection will throw it off balance, and at the high RPM that it gets to, the centrifical force will vibrate, and cause many problems.
One of them is to become loosened.
ED
de-nagorg is online now   Reply With Quote
Old 04-10-2019, 03:18 PM   #4
Rough Rooster's Avatar
Rewards Points: 418
Re: Loose blade
Have you replaced anything about the blade fastening?
It should have either a friction washer between blade and mount or a Bellville washer just under bolt head.
RR
de-nagorg likes this.
Rough Rooster is offline   Reply With Quote
Old 04-10-2019, 05:52 PM   #5
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,268
Re: Loose blade
posting the make and model of the mower you have will help.
the mower I have has the "star" center blade holder.
the hub with the male star is made to break away
when something is hit - vs breaking the crankshaft.
you won't know this unless you take the blade off and
examine the hub. if the star is sheared off, it must be
replaced. not that expensive and is an easy DIY project.
the hub is an easy online order replacement.
it is not threaded - just a friction fit held in place with the bolt.
if you order a new hub, you will receive a new bolt and
washer with it. use them - do not use the old hardware.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 04-17-2019, 12:08 PM   #6
Re: Loose blade
Rusty - Did you figure out your loose blade problem ??
John Deere Commercial Walk Behind Loose wire/won't start ajamison Tractors & Mowers 2 02-15-2019 04:00 PM
Help: loose deck boards on day 2 acordeon2 Building & Construction 8 07-06-2018 06:33 AM
Circular Saw - Blade Plug Problem ejseidman Tools 7 10-01-2012 02:04 PM
attaching circular blade to weedeater ugabulldog Landscaping & Lawn Care 1 09-25-2012 08:27 PM
Bosch Multi-X Blade DONE in 2 minutes miamicuse General DIY Discussions 8 06-25-2012 12:49 AM
