Leave Gas On Snow Blower Or Not - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree14Likes
  • 3 Post By de-nagorg
  • 4 Post By Let it Snow
  • 3 Post By stick\shift
  • 1 Post By ZTMAN
  • 1 Post By Domo
  • 1 Post By wpollock
  • 1 Post By Drachenfire
Old 03-19-2019, 11:48 AM   #1
Rewards Points: 16
Leave gas on snow blower or not
First time owning a snow blower. Craftsman 2 stage.
I always use sta-bil in my gas, dont have ethanol free.
Is it better to leave gas in or run it dry?
I've heard both. You want to leave gas on so it doesnt sry out the carb and lead to build up.
I've also heard to run it dry so the gas doesnt go bad.
Not sure which to do.
I've always left gas in my lawn mowers but that gets a lot more use.
Sent from my SM-G930V using Tapatalk
moosehaed is offline   Reply With Quote
Old 03-19-2019, 12:39 PM   #2
JUSTA MEMBER
Rewards Points: 2,548
Re: Leave gas on snow blower or not
Here, I run the small engines dry every season , so that any "varnish", will not build-up in the carb, and clog it's tiny ports.
If someone don't, any gas left in will eventually evaporate and plug them up.
Causing numerous problems down the road, and costing a new carb for the engine.
No sta-bil required, if you run it out of gas, before putting it away.
ED
Dave Sal, lenaitch and Johnny_inFL like this.
de-nagorg is offline   Reply With Quote
Old 03-19-2019, 03:31 PM   #3
Rewards Points: 342
Mine is over 20 years old. I've always added Sta-Bil and then run it dry. I've never had a problem.
Let it Snow is offline   Reply With Quote
Old 03-19-2019, 04:36 PM   #4
Rewards Points: 4,026
I run my mower dry in the fall and snow blower dry in the spring. I know people who have had to have units serviced due to having left gas in them during the off season.
Dave Sal, lenaitch and de-nagorg like this.
stick\shift is offline   Reply With Quote
Old 03-19-2019, 06:34 PM   #5
ZTMAN's Avatar
Rewards Points: 252
I always drain my snow blowers.
If you look in your owner's manual it will tell you how to prep your machine for storage. Craftsman gives you the suggestion to drain the fuel or , if you don't want to do that, add stabilizer.
Guess they don't think there is a difference
de-nagorg likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 03-21-2019, 01:06 PM   #6
Contractor/Engineer
Rewards Points: 1,084
All my equipment gas tanks have Sta-bil in them all the time...
I drain my tanks and run them dry - then blow out the fuel lines before seasonal storage.
Never had trouble - all start with one pull after a three priming pulls when starting back up.
Rubber/lines have not deteriorated due to crappy gas (when I can't find ethanol free). Although I have had to replace a few lines in the early days when they dissolved...
Domo is offline   Reply With Quote
Old 06-16-2019, 02:51 PM   #7
Rewards Points: 122
I second running the engine dry and emptying the fuel tank after having one heck of a time getting the carb cleaned/rebuilt on a Toro Recycler with 6.5 hp Briggs engine that had sat unused for two mowing seasons. I gladly put up with adding a little fuel to finish my last mow,leaf pick up outing knowing the unit will crank with little effort come next Spring.
wpollock is offline   Reply With Quote
Old 06-16-2019, 03:56 PM   #8
Big Dog
Drachenfire's Avatar
Rewards Points: 3,894
All the owners manual for my lawn/snow equipment states to use a fuel stabilizer (Sta-Bil) and run the machine dry before long-term storage.
My riding lawn mower is about 25-years-old. The push mower is about 19-years-old. The edger is about 16-years-old. Pressure washer is 16-years-old. Snowblower is 7-years-old. The leaf blower and trimmer are 13 and 7-years-old respectively. All still run perfectly fine.
In the interest of full disclosure, I run TruFuel only in the blower and trimmer. For those unfamiliar with it, TruFuel is pre-mixed fuel for two-cycle engines. It is available in 50:1 and 40:1 ratios and is made with ethanol-free gas. Even though there is no ethanol in TruFuel, I still run the tanks dry at the end of the season per the manual.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 06-16-2019, 09:42 PM   #9
Rewards Points: 702
I am the opposite. I do run Sta-Bil or something similar. And I have started to use Tru-Fuel. But, I have never shut the fuel off and run my engine dry. And, I have never had a problem starting them up the next season. I have done this with John Deere lawn tractors, Toro Snow Blowers and lawn mowers, and assorted other lawn care products.
I change the oil, change the plugs, put fresh gas in at the start of the season. Give it a couple of pumps on the primer. And then pull the starter. And away my wife goes on the lawn mower.
Guess I must be lucky.
I know a little bit about a lot of things. What I don't know, I research.
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
As a technical writer, I tend to be lengthy in my responses as I want to be accurate.
ktownskier is offline   Reply With Quote
Snow Blower Pull doesn't have tension Camper147 Tools 17 02-03-2015 07:52 AM
Snow Blower under load Arnie 1345 Landscaping & Lawn Care 3 10-31-2011 08:51 AM
snow blower repair hctr1963 Gardening Forum 4 01-15-2011 06:06 PM
new snow blower blows snow back emmiespop Tools 1 01-12-2011 07:43 AM
Snow Blower Repair Labrador General DIY Discussions 5 06-03-2008 12:26 PM
