Lawnmower Is Still Dead - Tractors & Mowers - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree18Likes
Old 05-29-2018, 07:59 PM   #31
Rewards Points: 60
Re: Lawnmower is still dead
Originally Posted by livnezsoon View Post
It's a new carb and look clean. I will open it up tomorrow and see if I have a stuck intake valve. I still have to try the oil in the cylinder trick that Guap0 suggested. Been raining on and off and wife and kids keeping me busy today. Hopefully I can try the oil trick and if that doesn't work, then open it up and look for stuck valve.
I was watching a YouTube video where the guy says the same thing happened to him and it was a stuck intake valve. I was thinking that it might make sense with the low compression. Will find out tomorrow.
Its been 4 days now and just checking on how the resurrection of the dead mower is coming along. Any promising news ?
Nealtw likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 05-30-2018, 08:24 AM   #32
Guapo
Rewards Points: 11,950
I think that you mean a stuck float valve/needle not the intake valve. If a float won't float, that would cause flooding. If something is stuck in the needle, you wouldn't get any gas at all. Usually. It still think that you just need to restore compression.
Guap0_ is offline   Reply With Quote
Old 05-30-2018, 10:15 AM   #33
Rewards Points: 40
After doing some digging, my best guess is a head gasket. Valves move freely, very dirty, but are not stuck. Head gasket didn't look good, but I don't know if that was from me taking the head off. I have a new gasket arriving tomorrow and will see if that was the problem.
Still seems like I am missing something. Can a head gasket go on you during supper?
I guess maybe it just happened to go when I turned it off or something about trying to start it back up after supper did it. Not sure. I will know more tomorrow. Not one place I called happened to have the gasket needed in stock so I have to wait for it to arrive by mail.
livnezsoon is offline   Reply With Quote
Old 05-30-2018, 10:19 AM   #34
Guapo
I doubt very much that you have a blown head gasket.
Old 05-30-2018, 10:40 AM   #35
Rewards Points: 40
All I know is that some of the videos I watched with low compression were due to the intake or exhaust valve stuck open. Mine seem to move freely and open and close as I would expect. I once thought is was the carb but a new one made no difference. I am hoping that the head gasket is the problem and try that when it arrives in the mail.
What I should have done was a compression test to see where the leak is. The kit should arrive with the gasket.
Old 05-30-2018, 10:46 AM   #36
Rewards Points: 40
I sure hope you are wrong as I don't know what my options are if the gasket doesn't help. I will do a dry compression test when the kit arrives in the mail. I removed the new carb and inspected it. Looks good. Made sure it was on nice and tight to ensure seal.
I found a place that has a replacement engine for a very good price. The store owner said he would hold it for me if the gasket doesn't work. This has cost me more than wanted but at least I have learned a lot.
Old 05-30-2018, 05:49 PM   #37
Rewards Points: 9,024
Originally Posted by lenaitch View Post
You seem to have spark and fuel. I wonder if it is flooding.
Either too rich or too lean. Too rich and you should be able to smell the gasoline. Too lean and it should run for a few seconds if you put a little gas in the cylinder.
SPS-1 is online now   Reply With Quote
Old 05-30-2018, 06:13 PM   #38
retired framer
Rewards Points: 4,796
Water in gas will give what looks like white smoke.
Old 05-30-2018, 06:37 PM   #39
Guapo
Did you try to bring back the compression with a few drops of oil in the cylinder? I'm sure that's all it is.
Old 06-01-2018, 07:16 PM   #40
Rewards Points: 40
Yes, I did. Maybe I didn't add enough as it didn't seem to help. I just received the new head gasket and will try that tonight or tomorrow morning.
There is a lot of carbon build up on the piston and intake and exhaust valve. Could that mean anything? I will try to scrap them clean. Any idea what to use to clean them? Carb cleaner maybe?
Old 06-01-2018, 07:30 PM   #41
Rewards Points: 3,272
Using water check the valves for leakage before doing anything else to the head.
Old 06-02-2018, 04:12 PM   #42
Rewards Points: 40
Was just getting ready to do that when I saw a problem. I could see light from the exhaust even with the valve closed. The valve looks fine. I don't see any problem with the shape, but I no expert.
I don't know if that means I need a new seat, valve or both. I still haven't figured out how to clean the carbon deposits off the valves. I know that I can't let anything get into the cylinder. Lightly scraping it with a putty knife doesn't seem to remove it. I don't know of any liquid to use.
I want to show the pic but can't upload as it wants a url.
Old 06-02-2018, 05:03 PM   #43
Guapo
Either use imgur.com to upload pics & post the link here or try to upload it to your personal album on this site. Either way, I think that you went way to far. I don't think that there was any reason to pull the head.
Old 06-02-2018, 05:10 PM   #44
He'll know when he flips the head upside down and puts about an eyedropper of water at the edge of the valves.
Old 06-02-2018, 06:31 PM   #45
Guapo
I know that it was a long time ago but in his original post, he said that he stopped for dinner. All that didn't happen during dinner.
Tags
lawnmower
No power to light switches and outlet Deco Electrical 6 09-12-2017 02:13 PM
Dead wood 2x4 for drywall missing in corner_ideas to fix tearitup Drywall & Plaster 2 02-01-2016 02:01 PM
Direction of dead bolt locks miamicuse Windows and Doors 6 04-19-2014 03:01 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 10:38 PM
