DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Tractors & Mowers (https://www.diychatroom.com/f106/)
-   -   Lawn mower starting issue (https://www.diychatroom.com/f106/lawn-mower-starting-issue-201809/)
syoung3765 06-06-2014 06:02 PM
I have a craftsman push mower with a briggs engine. The only way I can start the mower is if I prime a few times then I have to tilt the mower about half way on it's side then if I pull it will start in one or two pulls. If I do not tilt with I can pull and pull and it will never start. Any ideas on what I can check to try and fix this issue so I can start normally. I have even tried priming a few extra times and that does not help.
curtd 07-24-2014 12:57 PM
Off hand i would say the primer is not working. To check, remove the air filter, press the primer. You should see gas shooting into carburetor
joecaption 07-24-2014 01:16 PM
Very common for the primmer bulb to get a crack in it, most are easy to replace by just removing 4, small screws.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
