Lawn Mower Can't Start - Tractors & Mowers - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 01-22-2015, 10:13 AM   #16
A Little Of Everything
Rewards Points: 1,418
Originally Posted by Brad1231 View Post
I have the same problem with my MTD mover 11A-416Q729. It was used about a month ago and now won't start. Is the spark plug spark suppose to be yellow or a blue? I check the plug for spark and it sparks but it's a yellow color. I'm thinking it's suppose to be a blue colored spark? And does the primer red rubber button suppose to pump enough gas into the carb so I can see it pumping in when I remove the outside cover?
Thanks, Brad
The easiest way to tell if it's a gas or a spark problem is to shoot a little starting fluid in the carb (remove the air filter first) then try to start it. If it fires up then dies, you've got a fuel problem. You then work backwards from there.
My guess is that you've got some varnished gas blocking one of the orifices in your carb.
DrHicks is offline   Reply With Quote
Old 01-22-2015, 06:50 PM   #17
Rewards Points: 20
Thanks Dr. Hicks....... found out it MUST be the carburetor. Sprayed some of that fancy starting fluid into the carb and worked for 5 seconds. Actually that was a good thing since I was not looking forward to any additional work. Replaced the fuel line next and tried again.... worked for 5 seconds again so must be the carb. Gas was new so no old gas but that varnish is a killer. Can't think of how many times that screws things up. Anything you can use to keep that crap out of the carb? Or just some of that seafoam stuff? Maybe just run it more than once a month will help. Anyway, thanks for the heads up on the spark plug... (already replaced it for under 3 bucks. Got a couple new springs, (air vein and governor), filter, breather tube, primer bulb, and carb rebuild kit all for under 35 bucks.... sure beats the heck out of taking it to the shop.... probably better off buying a new one rather than take it to the shop.... Thanks again......... Brad
Brad1231 is offline   Reply With Quote
Old 01-24-2015, 03:29 PM   #18
Rewards Points: 332
Send a message via Yahoo to curtd
Originally Posted by rliu View Post
Thanks. I sprayed the Quick Fluid to the Carb. and the engine started running but stopped immediately. The oil or gas or combination of both was spreaded (pushed) out from the exhaust window when engine was running short time. Is it the problem of engine oil leaking or something else. Should replace the engine oil? How to drain it? Where is the leak. How to fix it?
The oil in the crankcase travels thru the valves area and then into the head if the lawnmower is tilted wrong. Oil also gets into the head with you have broken piston rings. Compression test will tell you
curtd is offline   Reply With Quote
Old 04-10-2015, 01:06 AM   #19
John
JD367's Avatar
Rewards Points: 206
Compression test on these engines WON'T tell you !
They have a compression release arm,on the cam, that is activated by centrifugal force .
The standard test for compression on the 3.5 to 6.5 engines,is to spin it ,by hand(with the spark plug wire off the plug!). just a quick flip. If it bounces back,it has compression.
Note,also that these engines only take 16 to 20 ounces of oil! Any more than that,and it will run into the cylinder,and cause lock up,or hard starting,and smoking.When the oil level is at the "add" mark,it will take 4 ounces.
Always make sure that the front,and rear wheels are adjusted the same height,for this reason !NEVER tip them sideways,or plug downwards!.
If you have to tip it(to clean under the deck,etc) tip it so the spark plug is UP !
JD367 is offline   Reply With Quote
Tags
engine , mower repair , start
Lawn Mower Question - Push or Riding? cbarr81 Tractors & Mowers 15 10-19-2012 09:44 AM
Replacing lawn mower pull cord nikeman Tractors & Mowers 2 09-10-2012 05:43 AM
TORO Lawn Mower vabear Landscaping & Lawn Care 1 09-01-2011 02:02 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
Ooops! Gas oil mix in lawn mower jamibe Landscaping & Lawn Care 7 04-12-2010 07:11 PM
