John Deere Z425 2007 Hard Start - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree4Likes
  • 2 Post By Bondo
  • 1 Post By SeniorSitizen
  • 1 Post By Windows on Wash
Old 08-11-2017, 07:10 AM   #1
Rewards Points: 8
John Deere Z425 2007 hard start
Had this problem last year but learned how to beat on carburetor bowl and start solenoid in bottom of float bowl. Before I ever try to start I look at the in line fuel filter bowl and it is clear full, don't believe this is normal. It will start and run for approximately 8 seconds and die, won't start again until I beat on bowl and start turning engine over and fuel will start moving thru filter. Will start and run OK from then.
Last night it started and ran approximately 1 and 1/2 minutes and died. Fuel filter was half full of fuel like it should be.
Any ideals? thanks
rickluc is offline   Reply With Quote
Old 08-11-2017, 09:18 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: John Deere Z425 2007 hard start
Ayuh,..... Here's a novel idea,....
Rebuild the carb, insteada beatin' on it,.....
joecaption and Mike Milam like this.
Bondo is online now   Reply With Quote
Old 08-15-2017, 06:50 AM   #3
Rewards Points: 8
Well got the carb. off. Took off the air horn with carb.. With air horn in vise and carb. bowl facing up, took off bowl and everything looks fine. Took air horn out of vise and turned upside down several times, float seemed to function properly. I realize just giggling around might of caused it to drop and retract. needle doesn't look bad. Put electric to solenoid and it seems to function right. I will say when I turned carb. right side up the two main jets fell out, should the O-rings on the main jets hold them in place in the emulsion tube?
So what are your thoughts? I will probably change float and needle value while I'm in there.
Old 08-15-2017, 06:58 AM   #4
Rewards Points: 1,510
Plastic needle valves are notorious for sticking closed. Replace it with a brass needle valve.
Jets falling from O rings doesn't seem like a good plan. Replace if you possibly can find the correct size.
Windows on Wash likes this.
Old 08-25-2017, 10:04 AM   #5
Rewards Points: 8
Replaced float pin and installed brass needle, all's well. Thanks
The Following User Says Thank You to rickluc For This Useful Post:
SeniorSitizen (08-25-2017)
Old 08-25-2017, 09:26 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,616
Score one for @SeniorSitizen
Mike Milam likes this.
Old 09-21-2017, 06:04 AM   #7
Rewards Points: 8
Follow-up question. Yes mower is still running fine. Have been watching clear inline fuel filter, after engine starts you can only see a trace of fuel moving thru it, no amount showing standing in it. Seems to me that the fuel level in this filter while it is running should be approximately 1/2 full of fuel? Thanks
Old 09-21-2017, 07:24 AM   #8
This is a borrowed phrase from an unknown individual and being I have an inquiring mind, I've been told, I break his rule sometimes.
"Son, you're worrying about things that don't need to be worried about"
Old 09-21-2017, 05:09 PM   #9
Dave Sal's Avatar
Rewards Points: 1,170
Probably not helpful, but early this year my Craftsman mower (with Honda engine) died on me completely. It had been hard to start for a couple of years prior but a shot of starter fluid always got it to fire right up. I assumed it was a fuel delivery issue. Then I bought a spark tester for a few bucks and found that I wasn't getting a spark at all. Ordered a new ignition coil from Amazon and installed it and it runs like new, no starter fluid needed.
Dave Sal is online now   Reply With Quote
Hard start capacitor? mikegp HVAC 11 07-19-2012 03:53 AM
Hard Start Kit ??? twinsportz HVAC 3 07-21-2011 12:44 PM
is a hard start kit needed???? firedogut HVAC 3 10-08-2009 06:33 PM
Snapper Mower engine hard to start czars Tools 3 09-02-2009 01:38 PM
Buying a Hard Start Capacitor Help D1G1T4L3CH0 HVAC 3 10-17-2008 08:42 PM
