JD Mower Kohler CV12.5s-1215 Stuck Valve? - Tractors & Mowers - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-12-2015, 05:58 PM   #16
Rough Rooster's Avatar
Rewards Points: 414
Yes, you can remove the aluminum cover with OHV cast into it and see the valve actuators and springs. You could rotate engine and watch for action on both valves. You could even check for bent or out of place push rod.
You won't learn any younger.
RR
Rough Rooster is offline   Reply With Quote
Old 05-12-2015, 06:05 PM   #17
Rewards Points: 706
RR
Was HOPING you'd be out there RR!! THANK YOU!! His only next question was about the gasket if it went south in the process. I told him I'd ask you!
Really appreciate it!
onjtrainee is offline   Reply With Quote
Old 05-12-2015, 09:57 PM   #18
Rewards Points: 414
Go out in backyard and dig up one of your Mason jars. Extract the wad of bills from it and head for your local JD dealer. They should have the gasket.
Or you could find one on Amazon or Jack's Small Engines and order it. (lot less money, but Oh, there is the shipping charge. )Be about a week or two.
RR
Old 05-13-2015, 08:35 AM   #19
Rewards Points: 706
RR
Since I wrote that I found this JD list of related items from the valve cover down. They have liquid gasket as one of the components for 3 bux and change. I was kind of surprised by that. Do you think this is the same engine?
Looks like it didn't copy/paste the diagram...but look at number 37
ly Air Filter / Mounting: FUEL & AIR BATTERY CHARGER KIT: ELECTRICAL BATTERY: ELECTRICAL BELT DRIVE & IDLERS GEAR: POWER TRAIN BELT DRIVE & IDLERS HYDRO: POWER TRAIN BRAKE LINKAGE GEAR: STEERING & BRAKES BRAKE LINKAGE HYDRO: STEERING & BRAKES CARBURETOR REPAIR KIT: FUEL & AIR CARBURETOR: FUEL & AIR CENTER CASE HYDRO: POWER TRAIN CRANKSHAFT,PISTON & SHORT BLOCK: ENGINE CRANKSHAFT,PISTON & SHORT BLOCK: ENGINE Cylinder Head & Rocker Arm - 290000: ENGINE Cylinder Head & Rocker Arm 290001 - : ENGINE DIFFERENTIAL & REAR AXLE HYDRO: POWER TRAIN ENGINE COVER & SHROUD 12.5 HP,14 HP: ENGINE ENGINE COVER & SHROUD 13 HP,15 HP: ENGINE ENGINE GASKET KIT: ENGINE Engine Oil Pump & Filter - 290000: ENGINE Engine Oil Pump & Filter 290001 - : ENGINE FLYWHEEL,IGNITION COIL & STATOR: ENGINE FRAME: WHEELS,FRAME,SHEET METAL & OPERATOR'S FRONT AXLE: STEERING & BRAKES FRONT WHEEL WEIGHTS: WHEELS,FRAME,SHEET METAL & OPERATOR'S FRONT WHEELS & TIRES: WHEELS,FRAME,SHEET METAL AND OPERATOR'S FUEL TANK & PEDESTAL: WHEELS,FRAME,SHEET METAL AND OPERATOR'S Gage Wheel Kit 38" Optional - 270000: MOWER DECK & LIFT LINKAGE GOVERNOR LINKAGE: FUEL & AIR HEADLIGHT KIT OPTIONAL: ELECTRICAL HOME MAINTENANCE KIT: WHEELS,FRAME,SHEET METAL & OPERATOR'S LABELS EXPORT: WHEELS,FRAME,SHEET METAL & OPERATOR'S LABELS FRENCH CANADIAN: WHEELS,FRAME,SHEET METAL & OPERATOR'S LABELS: WHEELS,FRAME,SHEET METAL & OPERATOR'S Mower Deck 38" - 270000: MOWER DECK & LIFT LINKAGE Mower Deck 38" 270001 - : MOWER DECK & LIFT LINKAGE MOWER DECK 46": MOWER DECK & LIFT LINKAGE MOWER DECK LABELS: MOWER DECK & LIFT LINKAGE MOWER DECK LIFT LINKAGE: MOWER DECK & LIFT LINKAGE Mower Deck W/Gage Wheels 38" - 270000: MOWER DECK & LIFT LINKAGE MOWER DRIVE BELTS,SHEAVES,SPINDLES & BLADES 38": MOWER DECK AND LIFT LINKAGE MUFFLER: FUEL & AIR MULCH KIT 38": MOWER DECK & LIFT LINKAGE MULCH KIT 46": MOWER DECK & LIFT LINKAGE Range Shift,Pump,& Motor Hydro: POWER TRAIN REAR WHEELS & TIRES: WHEELS,FRAME,SHEET METAL AND OPERATOR'S SEAT & SEAT PLATFORM: WHEELS,FRAME,SHEET METAL AND OPERATOR'S SHIFTER GEAR: POWER TRAIN SHIFTER HYDRO: POWER TRAIN Starter Marked 2509803: ELECTRICAL Starter Marked 2509804: ELECTRICAL STEERING WHEEL & GEAR: STEERING AND BRAKES TRANSAXLE BRAKE HYDRO: POWER TRAIN TRANSAXLE CASE HYDRO: POWER TRAIN Transaxle Shafts & Gears Gear Transaxle Marked 4360-68 OR 4360-100 SN -048531: POWER TRAIN Transaxle Shafts & Gears Gear Transaxle Marked 4360-68 OR 4360-100 SN 048532- : POWER TRAIN Transaxle Shafts & Gears Gear: POWER TRAIN Transaxle Shifter,Brake & Case Gear: POWER TRAIN Transaxle Shifter,Brake & Case Gear: POWER TRAIN WIRING HARNESS: ELECTRICAL Cylinder Head & Rocker Arm - 290000: ENGINESTX38 Lawn Tractor (13HP) -PC2399
Tag Part # Description Price Qty
33 15H558 Pipe Plug | 1/8in. HEX $2.63
30 37M7469 Screw | M6 X 25 $1.00
19 37M7459 Screw | M6 X 20 $1.00
14 AM107043 Retainer $1.66
15 M93483 Screw | REED VALVE;ORDER M153533,M92210 And M93483 $1.66
36 AM117021 Valve Kit | INTAKE (STD) (INCLUDES PARTS MARKED (B));Not Call Us
.. M92203 Cap | NLA; ORDER M146624, M92201 and M92203; EXHAUS $1.73
35 M92214 Exhaust Valve | OVERSIZE VALVE (INCLUDES PARTS MARKED (A)) (S $34.62
10 M92203 Cap | EXHAUST (INCLUDES PARTS MARKED (E)) $1.73
11 M92203 Cap | INTAKE (INCLUDES PARTS MARKED (F)) $1.73
21 AM124387 Kit | ROCKER ARM (INCLUDES PARTS MARKED (D)) (SUB F $28.60
1 AM125352 Head Kit | (12.5 HP, 13 HP, 14 HP) CYLINDER (SUB FOR AM124 $267.77
20 AM132623 Valve Cover | (SUB FOR M92209) $29.34
8 M120286 Spacer | (HEAD BOLT, EXHAUST PORT) $3.55
7 M120417 Washer $1.66
28 AM124387 Kit | GUIDE (NLA) (ORDER AM124387) $28.60
29 M124985 Strap | LIFT, (SUB FOR M92366) $3.55
12 M146624 Valve | (A)(C) $3.32
32 MIU14137 Seal | (15 HP) (A) (B) (SUB FOR M92202) $7.14
9 M149264 Bolt | CYLINDER HEAD, (SUB FOR M92367) $2.47
3 M149342 Push Rod | (SUB FOR M92197) $3.07
26 M153533 Retainer | BREATHER $3.32
31 M43123 Retainer | UPPER (A)(B) $4.32
4 M92198 Engine Cylinder Head Gasket | (12.5 HP, 13 HP, 14 HP) $14.35
6 M92201 Valve | (C)(E) $34.25
13 M92203 Cap | (A)(B)(C) $1.73
27 M92210 Beam | BREATHER $2.57
18 M92212 Hose | VALVE COVER VENT $3.90
25 M93483 Screw $1.66
2 MIU13278 Valve Lifter | Valve; SUB FOR M92196 or M131283 or M137271 o $15.26
37 PM37463 Liquid Gasket | (USE WITH AM132623) (SUB FOR TY15130 OR TY24 $3.85
17 TY22462 Clamp | HOSE $1.00
Minimum Orders Must Be $10 Before Shipping.
Most parts will ship from our shop within 5 - 7 business days.
There is no return on special order parts.
This Parts Catalog is made available as a service to our customers only.
It pertains to models sold in the United States only.
Reconfirm brand, line, year, and model and part numbers with our Parts Department if you are unsure before ordering.
Some older parts displayed in this section are no longer available. If no price is shown, it is
Old 05-18-2015, 12:52 PM   #20
Rewards Points: 706
Wow..can you believe this...we get the relay in, then the valves are stuck, we get the valve unstuck, and the new relay got wet and died...so I get a new relay, and the starter solinoid goes out! John Deere wants 90+ bux for it. Found it on ebay for 60.00. Do I have to go with exact John Deere part, or is there an equivalent that won't eat my lunch?
Kohler Tub/Shower Valve Rough In Docfletcher Plumbing 8 03-01-2013 03:09 PM
Cartridge stuck in a Kohler faucet Fan in Exil Plumbing 5 05-16-2009 12:53 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Expansion Valve Stuck Closed JustinD HVAC 3 08-31-2007 05:59 PM
