Husqvarna YTH24V48 Blowing Fuses - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-26-2016, 06:13 PM   #1
Rewards Points: 6
Husqvarna YTH24V48 blowing fuses
I have a Husqvarna lawn tractor that is blowing fuses. I have disconnected the negative battery terminal and have used a test light as I disconnected each harness connection to see when the light would turn off but nothing has turned off the light. I put everything back and tractor started but when I turned it off the fuse blew. Need help on what to do next.
Thank you
Jon
jonhaddigan is offline   Reply With Quote
Tags
lawn and garden , mower repair
Breakers are not blowing but fuses are? neo565 Electrical 17 09-12-2013 07:14 AM
Cut off switch for car battery blowing fuses IAmSupernova Electrical 141 05-28-2013 08:48 AM
Blowing fuses Coreysimp21 HVAC 1 12-12-2011 05:49 PM
carrier 38ycc heat pump blowing fuses headhunter89 HVAC 1 06-20-2011 06:45 PM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 06:21 PM
