Husqvarna Yth2448 Lost Compression - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-07-2015, 04:45 PM   #1
Rewards Points: 14
husqvarna yth2448 lost compression
Mower running well. Died and would not start. No compression at all. Thought flywheel was not turning engine, but checked spark plugs and it's firing, but no compression. Any ideas.
Joe Millard is offline   Reply With Quote
Old 07-24-2015, 01:27 PM   #2
Rewards Points: 194
Could be a bent or stuck valve.
billtech is offline   Reply With Quote
Old 08-14-2015, 12:47 PM   #3
funflyer's Avatar
Rewards Points: 432
How old is your mower? Is it a Briggs & Stratton engine? The older Briggs 24 hp twins had a few design problems. First was the air cleaner. It would seal when new but eventually, with age, allow dirt to bypass the filter. Second was a problem with the oiling system. On hilly terrain one of the connecting rods would starve of oil causing it to break. Both those would mean it's time to replace the engine or mower however, it could also be a valve issue that you can fix, see this video to help.
funflyer is offline   Reply With Quote
Husqvarna yth2448 flywheel doesn't engage engine Joe Millard Tractors & Mowers 10 06-19-2015 07:06 PM
Intermittant total compression loss? johnd393 Automotive Repairs 7 07-26-2014 11:08 AM
Brand new compression valve leaking EricBNeverScare Plumbing 6 08-14-2013 07:38 PM
Need to buy good value compression tester for a DIY'er- Suggestions? amodoko Automotive Repairs 4 02-11-2013 10:22 AM
Ceiling Anchoring of Compression Poles planar Building & Construction 1 08-07-2011 03:28 PM
