Husqvarna YTH21K46 Knocking Sound - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree3Likes
  • 1 Post By lenaitch
  • 2 Post By BigJim
Old 03-27-2019, 09:05 PM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
I just bought a used Husqvarna YTH21K46 mower, the motor and all works great. One thing I am a little concerned about is when engaging the cutting deck quickly, there is a loud like knocking. The noise stops as soon as the engine catches up. If I ease into the cutting deck, there is no noise. Any suggestions what I should check? The fellow I bought it from said it was belt slap.
I got such a good deal I figured if I had to fix something, I would come out ahead.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-27-2019, 09:44 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 720
Re: Husqvarna YTH21K46 Knocking Sound
I don't know anything about Husky specifically but many mower decks use a spring-held tensioning pulley as part of the belt routing. If that spring is shot or improperly installed it could cause belt slap or allow the pulley to hit something. Just a shot.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 03-27-2019, 11:11 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
Thanks lenaitch, I will give that a shot and see if that is it. I appreciate your help.
Jim
Old 03-28-2019, 08:50 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,838
Where are your RPMs when you engage the PTO?
Old 03-28-2019, 11:54 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
I don't really know, I would say about 3/4 throttle. I never ran our old mower wide open, but the manual for this one says to run wide open.
Jim
Old 03-28-2019, 07:18 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 720
Good point.
My JD manual says to engage the deck PTO at part throttle. I always figured it was to ease the strain on the electric PTO clutch but a 'hard start' of the deck drive might set things to slappin' and shakin'. A full throttle start on mine won't cause my deck to bang but other designs might.
Sic Itur ad Astra
Old 03-28-2019, 10:40 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
I am not sure mine is electric PTO. There is a lever behind the steering wheel that I push upward in a 1/4 circle. I have found if I ease into the cutting deck, it doesn't make that noise. I checked all on the deck today and everything is really in great shape, no slack or wobble in anything.
I thought I had really messed up today though. I had cut several stumps real close to the ground and thought it was low enough the blade wouldn't hit it, but it did. It killed the mower from wide open. I had to pull the lever to disengage the trans then pulled the mower backwards.
I was pretty perplexed about the possibility of messing up the mower that was one day old to me. I tried to crank it and it did crank but wouldn't go forward or backwards. I turned it off and checked every thing, then saw I have left the lever out that disengages the trans. LOL whew, I am a happy camper again.
I noticed the deck was cutting really really low on the right side, I checked several things and found when I hit the stump it bent the blade at a 90 degree about 3 or 4 inches from the outside edge. I went and bought new blades today.
Over all I am really happy with the mower, I guess I will just baby the mower and fix whatever tears up. I really do appreciate all your help.
Jim
Old 03-29-2019, 05:32 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 720
Close call. You could have bend something really important (read: expensive). Sounds like you've found your own solution to prevent the noise. It sounds like you PTO could be mechanically engaged. I'm not familiar with those. Maybe part of the linkage was banging or the torque of a high-RPM engagement transmitted some vibration.
BigJim likes this.
Sic Itur ad Astra
Old 04-10-2019, 12:23 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
Found the problem with the mower, the bolts holding the motor to the frame was loose. Tightened the bolts, no more knocking.
Windows on Wash and lenaitch like this.
Jim
double glazed window dennishcoook Windows and Doors 6 02-13-2016 10:04 PM
How would you Block Sound from the Room Next door? Respo Insulation 3 02-09-2016 12:25 AM
Budget Sound Proofing jessicurr Building & Construction 5 02-04-2016 01:15 AM
troubleshooting new sound card voltz PC Repairs & Upgrades 10 07-25-2010 12:16 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
