Greenworks 12 Amp Lawnmower Model No. 25022 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By shan1289
Old 05-09-2016, 01:47 PM   #1
Rewards Points: 83
Greenworks 12 amp lawnmower model no. 25022
Yesterday while cutting my grass with the lawnmower height adjustment at its lowest setting, I noticed that the blades don't come to an instant stop when I release the operating bar. It's like down whirling sound. Any ideas on the fix?
Thx.
Sent from my SAMSUNG-SM-N920A using Tapatalk
hawaiiboy is offline   Reply With Quote
Old 06-04-2016, 09:24 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Re: Greenworks 12 amp lawnmower model no. 25022
Brushes.
I hate signatures.
Mort is offline   Reply With Quote
Old 06-04-2016, 10:38 PM   #3
Rewards Points: 83
Originally Posted by Mort View Post
Brushes.
Motor brushes needed replacement?
Old 06-04-2016, 11:15 PM   #4
Mort's Avatar
Rewards Points: 696
Yup. Usually a motor brake not working is a sign the brushes need to be replaced.
I hate signatures.
Old 06-04-2016, 11:42 PM   #5
Rewards Points: 83
Disappointed if it's the brushes. Owned this lawnmower for only three years. Am trying to make a warranty claim though I find it very difficult in contact greenworks.
Thx.
Old 06-07-2016, 12:33 PM   #6
Rewards Points: 83
Finally got a hold of someone from Greenworks. Was told that it is a resistor gone bad which needs replacement. Will be getting a new resistor and I will see if it solves the problem after I recieve this item in the mail and install it.
Old 06-09-2016, 01:22 PM   #7
Rewards Points: 64
I was wondering how this would play out– Greenworks is supposed to have a 4-year warranty, so you should be covered!
hawaiiboy likes this.
shan1289 is offline   Reply With Quote
Old 06-10-2016, 02:42 PM   #8
Rewards Points: 83
Will let you all know after the resistor install.
Old 06-10-2016, 07:42 PM   #9
Rewards Points: 7,538
Makes sense to me.
SPS-1 is offline   Reply With Quote
Old 06-26-2016, 12:32 AM   #10
Rewards Points: 83
I finally found the time to replace the resistor. And yeah that solve my problem. Now the mower stops like use to when I disengage the power lever.
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
GE Profile Washer Model WPRE6100G0WT neither agitates nor spins tammy2006 Appliances 5 02-13-2010 01:33 PM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 07:04 PM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 03:24 PM
