Gravely Mower Dying After Hydraulic Fluid Change - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By JBG420
Old 06-07-2018, 02:43 PM   #1
Rewards Points: 40
Not sure if anyone can help. Have a Gravely zero turn (34z). Changed the hydraulic fluid following exact procedure in service manual. Moves and runs fine, but the mower (PTO) seems to lose power randomly. It feels like it would cuttong very thick, wet grass, when the mower bogs down, but Im not cutting qet, thick grass.
Any ideas? Thanks
JBG420 is offline   Reply With Quote
Old 06-07-2018, 03:05 PM   #2
Rewards Points: 1,858
Re: Gravely Mower Dying After Hydraulic Fluid Change
Was it doing the same thing BEFORE you changed the fluid ? If not, maybe some air in the lines? How are the lube points on the machine ? Lubed well ?
Gregsoldtruck79 is offline   Reply With Quote
Old 06-07-2018, 03:07 PM   #3
Rewards Points: 40
No it ran fine previous to the fluid change. Purged the syatem twice and greased everything up. Also checked the bwlt and its in good shape.
Old 06-07-2018, 04:31 PM   #4
Sure there is no need in asking but I will. Once the machine was ran up to normal operating temps, did you recheck the hyd. tank fluid level ?
Two threads are now open !
Old 06-07-2018, 04:38 PM   #5
Rewards Points: 40
Yes, after purging both times I ensured the level was correct on the dip stick.
Old 06-09-2018, 12:45 PM   #6
Rewards Points: 576
By any chance...did you measure the fluid coming out....vs. the fluid you put in ? And...is there a hydraulic filter somewhere ?
Cedrus is offline   Reply With Quote
Old 06-09-2018, 12:56 PM   #7
Rewards Points: 1,488
Maybe I'm reading this completely wrong but I can't recall hydraulics powering mower blades on a mower of that level.
Old 06-09-2018, 01:02 PM   #8
I wonder if it is this mower, which from what I can read would be hydrostatic controlled ?
https://www.mowersdirect.com/Gravely...er/p10440.html
Old 06-09-2018, 01:17 PM   #9
Under the heading DECK it reads: View Pic - if it will open
Pic doesn't open. Finally opened.
It Reads : ENGAGEMENT -----WARNER ELECTRIC
Old 06-09-2018, 01:31 PM   #10
Rewards Points: 40
Yes there was a filter that i had changed as well. One thing i noticed was that it did not drain completely (only got a quart out, manual says it hold 2.5). I jacked the mower up from 3 different points and worked the levers to push more fluid out. Im sure i have old and new fluid mixed now.
I did run it for a good 4 hours yesterday and it mowed fine. Didnt bog down at all but did notice it handle differently. Hard to describe but feels like the qheels are slipping at times. Ive also rechecked the hydraulic level several times and it is right where it should be.
Old 06-09-2018, 01:33 PM   #11
Yep. the mower blades are belt driven, I was looking for a source where the mower would use hydraulic fluid. The wheel/steering on the zero turn looks to me at least, is using a Hydro-Gear Fully Integrated Transmission....to me meaning it is hydraulic/hydrostatic. Not sure what the OP means by a PTO, as I did not know zero turns had external PTO's drives. I have seen them as an accessory on some of the old WheelHorse lawn tractors though but they were belt driven.
Old 06-09-2018, 01:36 PM   #12
Rewards Points: 40
Yes the mower blades are belt driven. I should not have used the term PTO. Bad habit.
Gregsoldtruck79 likes this.
The Following User Says Thank You to JBG420 For This Useful Post:
SeniorSitizen (06-09-2018)
Old 06-09-2018, 02:37 PM   #13
So the mower " moves and runs fine " but the blades RPM aren't staying up to speed?
Old 06-09-2018, 03:01 PM   #14
Reads like a fairly expensive mower. I think before I would risk damaging the hydro drives or whatever, I would drop it off at a Gravely shop and pay for a diagnosis. Then, depending on the mowers age or how long you want to keep it, decide what to do from there, if it is a real problem that requires $$$$$ . JMO
Old 06-09-2018, 03:33 PM   #15
Rewards Points: 40
Yea it was about $5k new. I bought it for $2k almost 8 years ago. Its a 34 inch deck and i have 5 acres to mow. I have no problem tinkering with it - breaking it - and having to buy a new one 😉
After some more diagnosing and talking to other Gravely owners, it seems the symptoms im describing are aimply worn wheel motors. I know it has been towed/drug at least once without someone opening the hydraulic bypasses........
Gravely walk behind commercial mower What have I done Tractors & Mowers 10 06-30-2018 08:46 AM
need to change trans fluid due to water in fluid WillK Automotive Repairs 2 09-07-2014 03:00 PM
ATF Never changed in 135K Miles - Leave or Change it? amodoko Automotive Repairs 46 04-26-2013 06:00 AM
Transmission fluid change y2k1234 Automotive Repairs 15 01-07-2013 08:10 PM
DIY Transmission fluid and filter change Bigplanz Automotive Repairs 13 06-22-2011 08:32 PM
