Gas Leak - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
  • 1 Post By lenaitch
  • 1 Post By Bondo
Old 04-24-2018, 08:05 AM   #1
Rewards Points: 66
Gas leak
I got my LX178 out of the shed from having sat all winter and found that I have gas leaking from what looks like a metal sediment bulb which is dripping on to my muffler. Any suggestions as to why I would have this dripping? Any thing I can do to stop it without taking it to the dealer?
smokeeater360 is offline   Reply With Quote
Old 04-24-2018, 03:05 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,174
Re: Gas leak
What you are describing sounds like the carburetor bowl. The bowl is mounted by a bolt up through the bottom which also has a fibre washer. If it was left full of gas it may have deteriorated the washer. You can try to source that washer through a JD dealer but it may come as part or a kit.
Check to confirm that where it is leaking from and you are not just seeing fuel leaking down from someplace else.
Gregsoldtruck79 likes this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 04-26-2018, 04:57 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Gas leak
Ayuh,..... Sounds like the fuel bowl is loose on the carb, or the carb's needle valve is stuck,... open,....
Probably oughta just rebuild the carb,....
joecaption likes this.
Old 04-26-2018, 05:20 AM   #4
Rewards Points: 1,864
Re: Gas leak
My now 24 year old John Deere started leaking gas in 2016, but it is not a lawn tractor...its a old tiller. I removed the leaking bowl, cleaned it out and flipped the washer over.
My JD carb bowl is still dry today, no leaks from it. Just got lucky I guess. Love my old Deere. I have not spent one dime on it in 24 years except annual oil changes/spark plug in its old Tecumseh engine and have worked it like a pair of mules. Not even a drive belt changed.
Gregsoldtruck79 is offline   Reply With Quote
2nd Floor Bathroom Leak KenOhio76 Plumbing 7 01-09-2018 02:10 PM
Roof leak hpmaxim Roofing/Siding 21 01-16-2017 08:49 AM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
