Gas Engine Running Poorly And How To Swap Gas - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree8Likes
  • 3 Post By BigJim
  • 2 Post By Bondo
  • 1 Post By ZTMAN
  • 1 Post By dalepres
Old 05-28-2017, 11:30 PM   #1
Rewards Points: 6,185
Gas engine running poorly and how to swap gas
My Harbor Freight gas-powered compressor isn't running well and I have to keep it on half-choke to run. It's basically brand new - I bought it 18 months ago and started it for about 5 minutes and it's sat ever since.
What I know is that the gas is what was in it 18 months ago so I'm pretty surprised it started at all.
I suspect the old gas as the primary culprit. The sign over the workshop door at my local mower shop says that 80% of their repairs are from bad gasoline.
The problem I have is how to get the old gas out so I can put fresh gas in. I know there are a lot of options but I want to get some opinions of others on what they use. I'm considering this: https://www.amazon.com/gp/product/B00QDC31VO
Thoughts? Anyone using something else for the job that they're happy with?
dalepres is offline   Reply With Quote
Old 05-29-2017, 01:15 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,347
Re: Gas engine running poorly and how to swap gas
That will work but all you need to do is go to wal mart and buy a pump bulb for a boat like that one in the picture, it will be cheaper.
This works pretty good also:
https://www.lowes.com/pd/Arnold-Siph...jDSGgJrLfD_BwE
After sitting that long you may have to take the carb off and give it a good cleaning, gas will gum things up after a good long period as it evaporates. I also recommend using non ethanol gas, ethanol is not kind to small engines.
dalepres, joecaption and Dave Sal like this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-29-2017, 01:33 AM   #3
Rewards Points: 7,054
About 6 foot of clear plastic tubing with a 3/8" I.D. from ACE hardware or any outlet that sells it / ft. works for me. To start the siphon I fill it with water from a re-purposed Ivory liquid dish detergent bottle. The Ivory bottle works much better than Dawn.
Old 05-29-2017, 05:32 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,450
Ayuh,.... Ya gotta pull the carb to clean it,....
Just extend the fuel line to a catchcan, 'n let it drain out,....
Dave Sal and ZTMAN like this.
Old 05-29-2017, 06:21 AM   #5
ZTMAN's Avatar
Rewards Points: 638
No offense to the OP but if you are asking the best way to drain gas, I assume you may not have the skill set to remove and rebuild a carb. I don't. Since the compressor is running, I would drain the gas and run some Seafoam through it. It will smoke like crazy, but may clean out the jets.
Dave Sal likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 05-29-2017, 11:21 AM   #6
No offense taken but that's quite an assumption. I got up this morning, dressed myself, tied my own shoes, and managed to turn on my computer, log into DIY Chatroom, and did it all by myself
I've rebuilt plenty of carburetors but won't be rebuilding one for this if it needs rebuilding; if it has to go to the shop I'll take it to the mower shop.
I've emptied plenty of gas and swallowed plenty in siphoning gas. I just know that there are a lot of folks here with a lot of experience and I just asked for the thoughts and advice of others.
Old 05-29-2017, 12:13 PM   #7
The only reason for the one I posted (and now ordered) is that it has the bulb to start and the bypass for gravity feed once started and I could order it from Amazon. They sell the same thing for about 27 dollars without the case but I want to keep the whole thing clean so I bought it with the case. I'm sure I could find something to keep it in to keep it clean but this was simple.
And we use Dawn so I guess the plain hose just wouldn't work.
BigJim likes this.
Old 05-29-2017, 12:37 PM   #8
You are certainly correct in that plain hose won't work. I've had a problem seeing when the water siphon starter in the hose changes to gasoline color so I quit using plain hose.
Old 05-29-2017, 01:55 PM   #9
Ole Wood Worker
BigJim's Avatar
Sc, do you just squirt the water up the hoes a good ways, but not so it goes into the tank, then let the water start the siphoning process?
Jim
Old 05-29-2017, 03:18 PM   #10
With the hose as pictured I fill-er up and install the plug, then with the hose in some position about vertical pull the plug to allow enough water to drain until none will enter the tank from the weighted ( nuts ) end.
Lay the plugged end ( fat pencil in this instance ) on the ground and put the weighted end that's void of water ( nuts in this instance ) in the tank. Pull the pencil plug and let -er rip until the hose is void of water then put the hose in a gasoline container if it's desired to save the gas.
And sure, gasoline can be used as well as water to start the siphon.
When I drove a 65 Ford Pickum-up truck I didn't even have a gas can for the mower. A regular gas hose with a shop towel wrapped around it and stuffed in the Ford gas tank then blow on the hose to pressure the tank. A slight learning curve required. With a full tank it was easy to over pressure and get a mouth full of gas though.
Old 05-29-2017, 05:12 PM   #11
Ole Wood Worker
BigJim's Avatar
Thanks SS, I thought that was how you were doing it. I use to put a hose in the gas tank and stick the air nozzle in the opening with a shop rag wrapped around the air hose to keep the air from escaping, pressurize the tank and there ya go. That is the same thing you did blowing with the hose, it works.
Jim
Old 05-30-2017, 09:14 PM   #12
One reason for not using the water-start is that I will burn the old gas in my truck, mixing a gallon here-and-there into a full tank of regular.
BigJim likes this.
