Ford 1210 Hydrostatic Clattering When Engaged - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-19-2015, 05:35 PM   #1
Rewards Points: 706
Ford 1210 hydrostatic clattering when engaged
Noticed clattering noise when backing and then pushed hydrostatic pedal forward to see if it quit, same thing....stopped chattering when I disengaged. I noticed a front hydraulic hose had blown so I replaced thinking that would fix it...but it's still making clattering noise. Not low on hydrolic fluid. Any ideas out there?
onjtrainee is offline   Reply With Quote
Old 02-19-2015, 06:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,450
Ayuh,... Where, Exactly, is the noise comin' from,..??
Old 02-19-2015, 07:03 PM   #3
Rewards Points: 706
Not in the engine...seems like it's coming from beneath the tractor...even thought maybe the shield covering the pto tied up with a wire might be catching...but that wasn't it.
I read where air in the hydaulic lines could make noise...but don't know about that.
Worried it's the pump...which is crazy expensive.
Old 02-25-2015, 12:53 PM   #4
Bondo's Avatar
Ayuh,.... Any update,..??
Any air in the lines should self-purge reasonably quickly,...
Is the pump externally mounted, or inside the casting,..??
Old 02-25-2015, 12:59 PM   #5
Rewards Points: 706
Joined two other tractor forums, picking as many brains as will let me. Am waiting on diagram from Ford New Holland re: placement of axel lube ports. Other than that, still bumfuzzled. Don't know if it could be a drive shaft coming apart or just something simple like needing to be lubed. Apparently it is lubed with hydraulic fluid from it's own designated port, which i sheepishly admit to never ever thinking of before now. Hope it's not too late. Love my little tractor, and it's never let me down before.
Old 04-10-2015, 12:22 AM   #6
John
JD367's Avatar
Rewards Points: 206
That trans takes 17 quarts,and if it's 2qts low,it will cavitate,and chatter.
It takes 3.6 seconds to pump 2 qts of hydro from a broken hose.
Recheck the fluid level,according to the manufacturer's directions.
JD367 is offline   Reply With Quote
Old 04-10-2015, 08:30 AM   #7
Rewards Points: 706
This is very interesting. I checked the level as soon as I'd repaced the blown hose. It was still reading high...but milky. Water had gotten in. In the process i realized whoever changed it the last time overtightened the central drain hole in the differential, and now I barely got the drain bolt out. It started to spin and retighten midway. I guess It has reamed out the central threads. Now I'm in the process having drained all the oil, trying to get an over sized self tapping bolt to work. I just got it in yesterday, it threaded two threads by hand, but falls out when I put a socket it on it. Not a mechanic, is this something I need to prebore or rethread the hole? Or have a mechanic do?
Old 04-10-2015, 08:59 AM   #8
John
JD367's Avatar
Rewards Points: 206
Water will cause the chatter,also. Hopefully,it hasn't caused damage to the pump!
Since it was cross-threaded, I would advise getting a mechanic to repair it,or,you can go to a local auto parts supplier,and see if they have an oil-pan drain plug repair kit,that will fit it.
Old 04-10-2015, 09:36 AM   #9
Rewards Points: 706
That's my hope as well....Will I still use the self tapping bolt or is that another wad of cash i just tossed out the window?
Old 04-10-2015, 09:50 AM   #10
John
JD367's Avatar
Rewards Points: 206
If you can use it,with out it falling ,do it.Just make sure it doesn't go in too far,and bind on a gear,or something. I'd still have a mechanic check it.
Old 04-10-2015, 10:29 AM   #11
Rewards Points: 706
No, it's actually shorter than the bolt that came out. I wonder what the kit you recommend is? Is it a tapp?
Old 04-10-2015, 05:51 PM   #12
John
JD367's Avatar
Rewards Points: 206
It is basically abolt ,with pipe thread on the outside that self -taps into a stripped out drain hole.
They come in different sizes,and simply screw in,and the center has a removable bolt to drain with.Here's a link to one type.
http://cgi.ebay.com/ebaymotors/24pc-...item35e64af33b
David is a Ford Guy now??? Bluwolf Off Topic 16 06-16-2013 08:54 PM
