Ethanol In Gas? - Tractors & Mowers - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 11-15-2015, 09:09 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 17,420
Originally Posted by SeniorSitizen View Post
Compatibility vs non- compatibility schedule. Note: The majority of O rings used in the equipment in question are of Buna-N. If you want better than that switch to Viton.
http://iqlearningsystems.com/ethanol...patibility.pdf
^^ That ^^
Fuel lines will go bad.....I had a car back before Ethanol with some cracked fuel lines....car was only about 5 years old.
I've been running standard Ethanol gas in my mower for 10 years now? No issues. None.....
I think you are worrying about a problem you don't have.
The Following User Says Thank You to ddawg16 For This Useful Post:
1985gt (11-16-2015)
Old 11-15-2015, 09:36 AM   #17
Rewards Points: 996
no problems with ethanol here. except for it not putting out the power %100 gasoline would.
btw, all of the small engines i have, the instructions say "DO NOT used premium gas"
Fix'n it is offline   Reply With Quote
Old 11-15-2015, 10:04 AM   #18
John
JD367's Avatar
Rewards Points: 206
Originally Posted by beenthere View Post
Isn't your Goldwing a pre 2001 model. Making it more then 15 years old. So Ethanol may not have been the only(if any) cause of a dirty tank, carbs needing rebuilt, and fuel lines needing replaced.
Very true,it probably was,BUT the fuel lines on most of today's machines are still the basic neoprene type,and the weed whips lines have not changed,either.
In the case of the Goldwing,most of the cleaning,and repair is due to stale ,gummy deposits in the carbs,and tank.
The lines,however were the standard rubber,or neoprene,and were destroyed by the ethanol.
Some of the manufacturers,are going to the more tolerant plastic-lined fuel lines.such as used in automobiles from the late 1980's ,on,but most don't due to cost.
Despite "Brand Names",the lawn equipment is made as cheaply as possible.
Briggs/Stratton's engines,are now made in China.
Kohler tried this,and went back to making them here,due to reliability issues.
New 'o' rings are more resistant,but aren't available in all sizes,but,in any case anything using ethanol,will eventually have problems .
Even the EPA admits ethanol should be taken out of motor fuels.
JD367 is offline   Reply With Quote
Old 11-15-2015, 10:17 AM   #19
Rewards Points: 996
i try to run my engines till empty and ran out of fuel. doing this leaves much less of a concentration to do harm. though, i am wondering, does 2 cycle mixed fuel have this problem ? as the added oil may sheild the hoses. idk, but i bet it helps.
Old 11-15-2015, 11:18 AM   #20
Rewards Points: 2,270
Everyone has an opinion.... Just because their opinion differs from yours doesn't mean they are wrong.
Me, I run Sta-Bil in all my small engines, and it seems to work well. I've had a lot less problems since going that route.
ktkelly is online now   Reply With Quote
Old 11-15-2015, 06:43 PM   #21
Rewards Points: 266
Europe does not use Ethanol in gas, yet small engines present the exact same problems with storage as in the US. Go figure...
nanuk is offline   Reply With Quote
Old 12-03-2015, 01:44 PM   #22
funflyer's Avatar
Rewards Points: 432
Are you sure about that? Better look it up.
funflyer is offline   Reply With Quote
Old 12-03-2015, 01:57 PM   #23
Low Slope Roofing
Rewards Points: 114
Fired up the ol snowblower last weekend to dig it out from under the deck and get ready for the snow. 8 month old ethanol gas with stabil, primed it 3 times pulled the cord and it started right up. Ran it for 20 minutes after I dumped a bit of sea foam in it.
Only reason I did it was because it was suppose to snow, of course I dug it out and it didn't snow enough to use the old beast.
1985gt is offline   Reply With Quote
Old 12-03-2015, 04:51 PM   #24
Ole Wood Worker
BigJim's Avatar
Rewards Points: 514
Ask anyone who knows about boat motors if they will use gas with ethanol in their motor.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-20-2016, 11:16 AM   #25
Rewards Points: 1,042
Re: Ethanol in Gas?
For anyone thats interested, heres a link for a chart showing where to buy ethanol free gas anywhere in the country, citys and towns are listed alphabetically.
http://www.pure-gas.org/index.jsp?stateprov=FL
Canarywood1 is offline   Reply With Quote
lawn mower died, now won't start mattsffrd Tractors & Mowers 17 07-25-2015 12:33 AM
mower problems john d williams Tractors & Mowers 5 05-29-2013 01:04 PM
New ' green ' concrete's on the way,,, stadry Concrete, Stone & Masonry 15 05-04-2013 08:57 PM
Briggs and Stratton Engine pwgsx Landscaping & Lawn Care 16 12-29-2011 06:42 AM
ethanol unleaded and power boats jayp Automotive Repairs 9 04-05-2009 03:12 PM
