Ethanol Free Gas - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree13Likes
Old 12-02-2018, 03:26 PM   #1
Rewards Points: 597
Ethanol Free Gas
I recently had a carburator replaced on my leaf blower because it had gummed up. The mechanic tells me to use ethanol free gas only. So now that is what I use. So my question is: Do I still need to use the recommended Fuel Stabilizer when storing it for next season?
rjordan393 is offline   Reply With Quote
Old 12-02-2018, 03:41 PM   #2
CodeMatters's Avatar
Rewards Points: 7,346
Re: Ethanol Free Gas
Not a direct answer to question but:
I used fuel stabilizers along with other storage methods for years and they
worked fine. Even so, 5-10 yrs ago I stopped doing any of that and switched
to running every engine for at least 5 minutes a few times during the off
season. This method has worked fine also. And I use ethanol free gases in
all these machines.
YMMV
CodeMatters is online now   Reply With Quote
Old 12-02-2018, 04:01 PM   #3
Rewards Points: 597
I think ethanol free gas must be something new in my area of Pennsylvania. The first time I seen it was at a WaWA store.
Old 12-02-2018, 04:38 PM   #4
Rewards Points: 534
In my opinion yes you need the stabilizer
mark sr likes this.
BayouRunner is offline   Reply With Quote
Old 12-02-2018, 04:48 PM   #5
Rewards Points: 18,204
This is coming from someone that uses gas powered tools to make a living.
In the off season all my mowers, trimmers, post hole diggers, Ect.
I dump all the fuel I can and just let them run until there out of fuel.
Every single one of them start with no trouble in the spring.
Old 12-02-2018, 04:49 PM   #6
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,268
using ethanol free gas, you will experience less fuel delivery
issues. stabilizers is your choice, depending on your weather conditions.
keeping the gas tank in any machine either completely full or completely
empty during long periods of inactivity reduces the likelihood of moisture buildup
in the gas tank. whether it be a lawn mower, boat or an old Ford 8N tractor.
why not call the shop that replaced the carb on your leaf blower
and see what they recommend for your area.
mark sr likes this.
Johnny_inFL is offline   Reply With Quote
Old 12-02-2018, 05:09 PM   #7
JUSTA MEMBER
Rewards Points: 998
I too run the tool until it is out of gas, store it, and in spring, refill the tank and fire up, no gumming up, no mess to clean.
ED
de-nagorg is offline   Reply With Quote
Old 12-02-2018, 05:29 PM   #8
Rewards Points: 597
Thanks All,
I'll keep the advice in mind depending on whether the fuel tank is near empty or still has a considerable amount left. Trying to siphon it when there is plenty left would be too troublesome and I would prefer to top it off.
But if near empty, I would run the tool as suggested.
Old 12-02-2018, 05:44 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 160
Go to "puregas.com" to find ethanol free in your area.
Sent from my RCT6213W22 using Tapatalk
Windows on Wash likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 12-02-2018, 07:36 PM   #10
Rewards Points: 2,534
A lot of small-engine tools have a fuel shutoff in the line. You can also buy one pretty cheaply for those which don't. Then you can keep the tank full, shut off the valve while it's running, and let the carb run out of fuel. Stay close by and slowly close the choke as it starts to die, to be sure you've got every last drop.
de-nagorg likes this.
CaptTom is offline   Reply With Quote
Old 03-02-2019, 08:31 PM   #11
Rewards Points: 102
Wawa sells ethanol free gas around here.
ChuckTin is offline   Reply With Quote
Old 03-03-2019, 06:30 AM   #12
retired painter
Rewards Points: 1,362
I'll run my lawnmower and weedeater out of gas every fall and store it that way. I've used that method for 40+ yrs. My chainsaw gets used all year but might not get fired up for a month or two so I always add Stabil to the gas [non ethanol] unless I know I'm going to do a lot of cutting. Same thing for my leaf blower.
mark sr is offline   Reply With Quote
Old 08-17-2019, 06:32 PM   #13
Rewards Points: 586
https://www.pure-gas.org
Let it Snow is offline   Reply With Quote
Old 08-17-2019, 07:36 PM   #14
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 252
I have never used a stabilizer or ethanol free gas. My push mower is 10 years old and starts first pull. My rider is a 1990 model and after a new battery every spring starts easy.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-17-2019, 07:40 PM   #15
Reason this old thread is being revived?
Free building supplies? DangerMouse General DIY Discussions 7 07-01-2011 07:48 AM
Home Depot, Lowes, and Free Shipping mdawson3k General DIY Discussions 1 05-23-2011 03:06 PM
Free POT! DangerMouse Off Topic 13 04-25-2011 12:58 PM
