Engine Stops After Disconnecting Battery - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
  • 1 Post By de-nagorg
  • 1 Post By SeniorSitizen
Old 03-14-2019, 04:52 PM   #1
Rewards Points: 2
Engine stops after disconnecting battery
After about an hour of grass cutting on my Dixie Chopper 27hp equipped with a Guardian engine, the mower completely shut down. I eventually checked the battery voltage and found it was at < 7 volts. I charged the battery and it started and sounded fine. After thinking about this, I started to wonder if I'm seeing an electrical issue and I started checking the fuse and regulator. I did find a lose wire on the regulator terminal which feeds into the battery and secured it. I then checked the voltage to the battery while running the engine which read >14 volts. After further thinking about this conundrum, I decided to disconnect the battery after starting the engine and the engine stopped. At this point, I'm not really sure if this is normal or this is a stator, regulator or some other issue. Thoughts please.
Many Thanks
Lakesport is offline   Reply With Quote
Old 03-14-2019, 04:59 PM   #2
retired framer
Rewards Points: 6,224
Re: Engine stops after disconnecting battery
You could also have a loose connection any where the power goes on it's way to the battery, the key switch or relay,or what have you.
Do not use flat bottom gables with scissor trusses.
Old 03-14-2019, 05:02 PM   #3
JUSTA MEMBER
Rewards Points: 1,612
It should run with no battery, after cranking and starting.
A component somewhere between the regulator, and ignition is faulty, or loose.
ED
Dave Sal likes this.
de-nagorg is online now   Reply With Quote
Old 03-14-2019, 05:41 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,548
https://sites.google.com/site/rivers...tion-coil-work
Old 03-14-2019, 06:49 PM   #5
Rewards Points: 3,656
If the engine is equipped with a carburetor fuel solenoid shut off valve it will die if the battery is removed. The < 7 volts probably killed it initially.
lenaitch likes this.
alarm system - low battery glitch and transformer problem eastvantrading Electrical 10 01-05-2015 01:01 PM
Removing a stuck flashlight battery Thurman Electrical 8 12-28-2013 10:23 PM
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 06:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
